Forums › Forums › iLive Forums › Archived iLive Discussions › suggestions
- This topic has 537 replies, 136 voices, and was last updated 11 years, 4 months ago by KB7981.
AuthorPosts
2012/03/22 at 12:47 pm #30086AnonymousInactive
My biggest issue is the lack of support for the dual mix rack setup. You still can not set this up offline, it is not considered in the IPAD software, and there is no easy way to add a monitor desk. It appears as though Yamaha has done this with the new CL series using more than 2 mix racks. I love my system just wish the dual rack was truly embraced.
112T
IDR16
IDR31Chad
2012/03/23 at 11:41 am #30093Lieven-DewispelaereParticipantDigital compensation just like the new CL
it should be possible as the digital stage is also in the rack
Then it would be possible to have 2 surfaces connected to one rack ( if one rack can handle 2 different PFL busses, that is)
quote
Compensation gain is applied at the digital stage of I/O rack and can work to compensate the analog gain changes by moving in the opposite direction, which allows multiple consoles to take the compensated (stable) input signals. The compensated signal is also delivered to other Dante devices such as computer and other consoles equipped with Dante, because the gain is compensated at the I/O rack stage, not in the console.”
End quoteLieven
T112/IDR48/R72/IDR16/xDR16/2ACEcards/IPad1
Save a tree, eat a beaver2012/03/25 at 3:10 am #30097mervakaParticipantA rather simple one:
I’d like to see the channel SEL/MIX buttons in editor available as control types in the MIDI control map.
2012/03/25 at 10:17 am #30098timtraceParticipantquote:
Originally posted by steffenromeissquote:
Originally posted by timtraceStill hoping for “Key Listen” to be added to the IP noise gates.
select button in the keyfilter section does this already
Does this work in the Editor? I’ll have to give it a go!
2012/03/25 at 4:50 pm #30100SteffenRParticipantIt works on the surface, so why not on the editor?
SRV-AVB
R-72, iDR-16, xDR-16, Dante2012/03/25 at 10:23 pm #30108pblosser03Participant1. Scene management in the ipad app.
2. Iphone app for monitor mixes, so musicians can tweak their own mix. (See https://iliveforum.allen-heath.com/topic.asp?TOPIC_ID=1883)
3. Fader to 0 in editor software (just double click on fader?)
4. Strip meters on DCAs would be nice.
5. Multiband Comp & Dynamic EQ
Peter2012/03/26 at 9:30 am #30110TuejoParticipantI just got a crazy idea that I dont think has been mentioned before. How about adding some form of dynamic eq and multiband compression? Or just as the Vi6 did, add ratio, Q, Attack and release to the deesser…
I like the monitor mix app idea for musicians.
2012/03/26 at 12:43 pm #30112SteffenRParticipantquote:
Originally posted by TuejoI just got a crazy idea that I dont think has been mentioned before. How about adding some form of dynamic eq and multiband compression? Or just as the Vi6 did, add ratio, Q, Attack and release to the deesser…
It was mentioned 100 times before…[]
SRV-AVB
R-72, iDR-16, xDR-16, Dante2012/03/31 at 8:06 pm #30304searchieParticipantI’ve been getting familiar with my iLive system, having decided to acquire one after seeing on youtube how Memphis Train Revue used theirs
https://www.youtube.com/watch?v=MfWCxS6ThHY
I tend to do very small shows but, when the band has their own engineer, I can see that not having a traditional surface can be anything from a minor annoyance to a headache. To be honest sometimes I miss having a surface.
The big advantage of using an iLive system with iLive Editor for me is that, it allows for some division of labour. If the band wants to record the show, I can configure a stereo matrix or configure a stereo aux, give an engineer a computer and let them mix their own recording. If their is a broadcast going on I can do pretty much the same thing. I can also have a separate computer mixing monitors as well as, one to manage the FX rack and FX mixes. I could even let fussy artistes mix their own monitors if they’re so inclined.
I’m sure everybody’s eyes are popping out of their heads but, what if there was a way to restrict Tony, Bob and George to their own aux/wedge mixes while the recording guy could only select the recording aux/matrix and the same for broadcast guy and the FX guy. If there is a way, I haven’t been able to find it. If there isn’t I guess it could be implementing a list of mixes that a particular user can select (or an exclusion list) and then have the different people log on as different users. Does that make sense or am I opening a can of worms?
I couldn’t run the risk of having to run over to the broadcast truck to tell the broadcast engineer that he just muted the MC’s mic for the FOH mix when they cut away to their talking heads all because he selected the mains by accident.
Alan
2012/03/31 at 11:46 pm #30305SteffenRParticipantquote:
Originally posted by searchieThe big advantage of using an iLive system with iLive Editor for me is that, it allows for some division of labour. If the band wants to record the show, I can configure a stereo matrix or configure a stereo aux, give an engineer a computer and let them mix their own recording. If their is a broadcast going on I can do pretty much the same thing. I can also have a separate computer mixing monitors as well as, one to manage the FX rack and FX mixes. I could even let fussy artistes mix their own monitors if they’re so inclined.
That’s why you should use a second mixrack for broadcast. Then you do a mic split and the broadcast guys have everything by their own system except the gain for the inputs.
The monitor mix for the musician is a different thing…
SRV-AVB
R-72, iDR-16, xDR-16, Dante2012/04/01 at 1:26 pm #30310mumuParticipanti do “give a laptop to the broadcaster” all the time if the band is not too “channelconsuming” i even use a triple channel split.
(20 foh trim /20 broadcast trim /20 monitor “gain chief”)
for the broadcast laptop i reserve one effect (called radio) –
and make him a custom layer.
as you can see in the example he gets all the fex returns.and has full processing as he has his own channels.
works pretty good for small shows.
now (b)locking the top bar in editor feature would make things “securer”
ps: for bigger broadcast i use a analogue mic splitter and give em a separate ilive rack
then they have full gain controlcheers
daveallways latest firm and software
iLive-144/t-80/idr-10 /idr-48/dante/pl-6/eyepad 1/belkin router/2012/04/01 at 3:38 pm #30311DaveParticipantSeems like the editor would need a “live” mode that just presents the configured strips and not the ability to reconfigure them. Seems this should be pretty simple to configure; just hide the appropriate toolbar items and menus, hide Setup Mode for the channel strips, lock the custom strips tabs, and password protect the whole thing.
iDr48/T-112/MADI
2012/04/02 at 12:58 pm #30312VOLCANOJEFFParticipantThe Above mentionedby dburris….
1++. This would make for a secure method of doing many things with editor that I would not do now…Due to the inability to trust some to either not make a mistake and fool around with anothers mix. not that any musician I know would do it intentionaly :0.JEFF FLOWERS
VOLCANO ADUIO PRODUCTS
SHEPHERDSVILLE KY-USA2012/04/05 at 9:01 am #30331timtraceParticipantquote:
Still hoping for “Key Listen” to be added to the IP noise gates.quote:
select button in the keyfilter section does this alreadyquote:
Does this work in the Editor? I’ll have to give it a go!quote:
It works on the surface, so why not on the editor?Can you help me with this? Here’s a screencap of the 1.83 editor with the gate window open. There’s no SEL button in the key filter section of the gate window. If I click the SEL button on the channel strip in the I/P window, it just causes the processing window to pop up again…I don’t hear a gate key listen. So I’m confused
2012/04/05 at 12:06 pm #30333SteffenRParticipantquote:
So then it’s not possible in the editor. Is it possible to use the touch screen emulation and the editor at the same time? Then you should be able to use the select buttons in the touch screen emulation.
SRV-AVB
R-72, iDR-16, xDR-16, Dante -
AuthorPosts
- The forum ‘Archived iLive Discussions’ is closed to new topics and replies.
