This topic contains 499 replies, has 120 voices, and was last updated by Profile photo of tourtelot tourtelot 5 days, 1 hour ago.
Viewing 5 posts - 496 through 500 (of 500 total)
  • #111831
    Profile photo of alax
    alax
    always use good quality oil during oil changes.[url=https://logicfleetservicecentre.ie/our-services/oil-change/]Oil Change Dublin[/url].oil changes should be done on time which will make our vehicles better.
    #111846
    tourtelot
    Moving on from oil changes, I am stress test recording on my SQ6 today with a spinning drive, a OWC Mercury 1TB with external power supply. 32 tracks 24/48 for a 2-hour burn. Got an hour to go. If all the files load into Reaper with no errors, I will take that drive on the next job, along with my JoeCo as a life preserver. More to come.
    D.
    #111848
    Profile photo of Giga
    Giga
    What is this Joeco you’re speaking of ?
    Btw, I use a Sandisk extreme usb3 thumb drive with great results…
    Giga
    #111850
    tourtelot
    Just DL’d 32-tracks off the OWC Mercury drive and all the files loaded into Reaper and play back. Maybe the bus-powered Samsung SSD just can’t handle the load of a big track count. The OWC drive is externally powered. I have a 1TB SSD coming from OWC next week. Same footprint. I’ll test it then and report back.
    My JoeCo BBR-64 Dante is a Dante enabled 64-track dedicated recorder. https://joeco.co.uk/bbr64-dante-joeco-multi-track-audio-recorder/ Never failed me.
    D.
    #112010
    tourtelot
    The OWC Mercury On-The-Go 1TB SSD seems to have faired just as well. 32-tracks of 24/48, two-hour recording. All files downloaded and played back in Reaper.
    A couple of on-the-job tests sohould be enough to restore my confidence in recording on the SQ.
    D.
