This topic contains 510 replies, has 126 voices, and was last updated by Mike G 6 months ago.
2016/01/18 at 1:50 pm #53346
Please note that this is thread is for compatibility of branded, commercially available USB Devices only.
Hi All, as you know, it’s extremely difficult and time consuming to test every USB device available on the market!
I’ve come up with a solution to community-source this info, which I hope you’ll assist with. 🙂
I’ve created a quick’n’easy form for you to enter the details of devices you’ve tested, which will generate a user-approved device list.
Before proceeding, please familiarise yourself with the information about Qu-Drive in the Qu Mixer Reference Guide V1.9 and the Understanding Qu-Drive and USB Devices knowledge base article.
Manufacturers can often change device components and specifications without notice, so you’re welcome to enter devices which have already been submitted by other users, <span style=”text-decoration: underline;”>particularly if you find different results</span>.
Again, this is for branded, commercially available USB devices only!
We’re only interested in complete sets of results so, please test all devices fully before submitting entries.
This list won’t be officially approved by A&H, but we may take the most popular devices or those with ambiguous results and test for verification.
Enter devices in the form here: https://www.allen-heath.com/usbdeviceform/
See the list of tested devices here: https://www.allen-heath.com/usbdevicelist/
Again, for further questions about Qu-Drive please refer to the Qu Mixer Reference Guide V1.9 and other Qu-Drive related threads by searching in this forum
Please don’t hesitate to get in touch if you have any queries.
2016/02/02 at 8:49 am #53660Hello,
I also buy a USB key sandisk cruzer 16gb made .
My problem , and that the A & H QU- 32 does not format the key !!! :
would you have a solution ??
Best regards
Jeans2016/02/04 at 4:03 pm #53722Hi John, you have not specified the exact model of SanDisk Cruzer.
We have not found that this is the case with the following models, however that does not mean that this is the case now.Cruzer Blade
Cruzer Edge
Cruzer Facet
Cruzer Fit
Cruzer Force
Cruzer SwitchLooking at SanDisk’s website it looks like we have not tested the Glide, Orbit or U from the Cruzer series.
Can you confirm which model this is please?
Thanks.
Harry.2016/02/12 at 12:43 am #53860@harry: Could you please correct the link to Understanding Qu Drive and USB Devices? Your’s isn’t reachable without helpserve login.
2016/02/12 at 8:18 am #53863the recommended usb drives from this website https://allen-heath.helpserve.com/default/Knowledgebase/Article/View/774/0/qu-drive–understanding-qu-drive-and-usb are not!! save. i bought exactly the Verbatim Store ‘n Go 128GB USB3.0 External SSD. that does not work.
very thankful for the list!
2016/02/12 at 10:57 am #53868@monom Hi Jürgen, have you followed the instructions in the Qu reference guide and the steps in the questionnaire for testing the device properly?
In the opening post I have said:
“You’re welcome to enter devices which have already been submitted by other users, particularly if you find different results, as manufacturers can often change device components and specifications without notice.”I have corrected the link to the knowledge base article and now added a field in the questionnaire where Digital Community users must enter their username for validation and clarification purposes.
Thanks.
Harry.2016/02/12 at 11:01 am #53869i bought the allen & heath recommended “Verbatim Store ‘n Go 128 GB SSD`and it does not work in any way. nothing is shown. only “no usb device” i formatted the device in fat32 with my mac, also not shown in the q16 menu.
2016/02/16 at 3:08 pm #53971Hi all, as of now, we will be removing the Verbatim Store ‘n’ Go 128 GB SSD from the compatible devices list.
Many thanks to Jurgen for his assistance in qualifying this.
Cheers,
Harry.2016/03/06 at 12:45 pm #54432Hi Harry,
I bought the Sandisk Extreme USB 3.0 16GB (unto 245mb/s read speed,50 MB/s write) which is one of the recommended USB in the list but it is not working. I have formatted it via Utility/QU Drive but I am always getting a 512 bytes in any of my recording. Recording is running but the elapse time is not.
Then I also tried to copy to playback but the board is reading it as unsupported file.
Hope you can help me with this issue I’m facing.
Thanks.
2016/03/06 at 1:01 pm #54433Sure that you hit Record after arming?
2016/03/06 at 3:40 pm #54438oh yes Andreas. Thanks a lot. I thought the record button is enough.
2016/03/21 at 6:33 pm #54687Good day all!
A question of “general compatibility”.
If a 16GB USB 3.0 drive from a particular manufacturer (PNY) worked to transfer software updates to the mixer, does that necessarily indicate a higher likelihood of a larger drive from the same maker being compatible with the QuDrive?2016/03/21 at 9:00 pm #54690Easy: No
Larger size does not necessarily provide higher speed, nor does USB3 generally mean the stick is faster than some USB2 version.
Even if you 16GB stick works for audio streaming (does it?), it does not guarantee that a larger one would work as well.2016/03/22 at 12:18 am #54693Thanks for your insight, Andreas!
2016/03/28 at 10:26 pm #54801Quick update; my daughter thought to buy me one of those PNY thumb drives because she heard me discussing it with my son… and it worked!
I have gone ahead and filled out the form/questionnaire to let A&H know all the particulars.Attachments:
