Forums › Forums › dLive Forums › dLive feature suggestions › Metering on DCA faders
This topic contains 42 replies, has 22 voices, and was last updated by Josh 1 week, 1 day ago.
2019/05/03 at 7:45 pm #83668
well… @davidco
metering the hottest signal means that you can see if there is a signal or not
maybe you got a different solution?2019/05/03 at 7:46 pm #83669The solution is to implement the same functionality that Yamaha and Behringer do. As I say, it’s incredibly simple to do.
2019/05/03 at 8:23 pm #83671I’m all for the DCA metering. I have many shows that run 90% on DCA’s and while I can work around it (mostly) with meter pages on a desk, there isn’t a workaround on an ipad. I’ve had some minor panics where I thought I had no signal because the day before I was on an X32 with DCA meters.
Remember that these meters have ballistics (attack, release, peak hold) and the “software” is actually implemented in an FPGA, so you aren’t simply dealing with a CPU/DSP summing arrays.
A sum of channel levels, integrated independently over time with attack/release, with no relation to frequency content is meaningless.
As a perfect example: take 2 channels with the same signal in phase and equal levels and sum them, the output is +3db higher than what went in. If I take the same 2 channels, flip the phase on one, the “sum the levels method” would still say +3db(ish) and there would be no signal coming out the other side.
They either have the hardware capability to do it right or they don’t, aside from an indication that an individual channel is clipping there isn’t a shortcut that works for the general case.
Jay
2019/05/03 at 9:35 pm #83679@jay
why are you asking it again? did you read the whole topic?
it is simply not possible…2019/05/03 at 9:53 pm #83680it is simply not possible…
What makes you say that?
2019/05/04 at 1:08 pm #83686Metering in DCA that is true metering and measures correctly needs summing and this needs busses 24 DCA mean 24 busses only for metering
to calculate metering readouts without weighting is no option because it offers completly wrong results
and if you add busses and inputs to a DCA (that helps organizing your channels for spill) the summing will also lead to irrelevant resultsI agree that peak and signal present indication would be possible and helpful
as @davidco already mentioned2019/05/04 at 5:39 pm #83689It’s much easier than the summing that happens when you PFL a DCA, because the audio doesn’t need to be summed as it would be for a PFL (summing the audio is a more complex function). Only the channel levels need to be added, which are available for all channels at all times (see the meter page). Just simple addition of the numbers that are the AFL levels of the channels, that’s it.
Let’s suppose there are two input channels, both fed a sine wave from the signal generator, and we polarity invert one of them. Now let’s feed them both to an audio group but also set them as members of a DCA.
Q: With the audio group summing the two signals together and measuring the level post sum, what does the group metering say?
Answer: they cancel out, there is no visible signal on the meters.Q: If you sum the metering data of each of the DCA’s members, what would the “DCA metering” say?
Answer: Each member’s metering data doesn’t take into account its phase or polarity, so the levels will just be blindly added together without respecting coherency, and will behave the same regardless of phase/polarity with respect to each other.I am a programmer, and integer sums are probably one of the simplest operations a computer can do.
Being a programmer doesn’t qualify you to talk DSP though.. Quid in the post, please.
DC
2019/05/04 at 8:43 pm #83692The example with the signals in phase opposition is quite interesting.
but it is only valid in extreme cases. The extreme case of mutually perfectly extinguishing signals hardly ever occurs. But you could also reply here: on a bus the signals would cancel each other out, but the inputs could still be overdriven and cause distortions elsewhere. So it would still be good if there were a display of the strongest signal.In real situations, it has been shown that a display of the highest level in each case has proved its worth. it’s not for nothing that colleagues who know the other consoles would like to have something like this in the dLive.
2019/05/05 at 4:00 pm #83698This is getting a little crazy.
It can and has been done on other consoles, like the Yamaha and Behringer/Midas, therefore it can be done on the dLive. Don’t worry about how they would specifically go about that, just put the request in so they know that it’s a wanted feature.
2019/05/05 at 7:53 pm #83700Past in the nineties there was a slogan in the biggest german electric company published to their employees: „better the second best solution now than the best one never.“
Some of us can do teir jobs with one single „chromatic“ LED per channel on the SQ series. But on the dLive we need full accuracy on that tiny 10 segment channel metering? Hm. Imho four states are required: too less, right enought, close to clip, overload. Thats it, at leastfor music jobs.2019/05/12 at 4:06 pm #83790I had another show yesterday when I forgot that DCA didn’t have functioning meters. DCA metering is a must and I’m truly hoping it will be implemented in the next firmware release. An alternative might be a Group Spill – the same functionality as DCA spill but for input channels routed to a Group. For now I need to make two kinds of grouping – signal grouping to get my drumkit, multi mic’ed guitars, synths, etc. on single group faders on the main show layer (A) and DCA groups assigned to Soft Keys to spill the children of those groups on the surface. With DCA metering I could do without some of those signal groups. Of with Group Spill I could do without DCA grouping.
2023/05/03 at 8:13 am #112686Yes please another +1 for DCA metering. It’s so helpful!
2023/05/24 at 5:52 am #113005+1 For some kind of indicator of audio signal on an open, unmuted DCA
