Forums › Forums › Qu Forums › Qu general discussions › How to Solo Inputs on the QU16
- This topic has 16 replies, 7 voices, and was last updated 6 years, 3 months ago by magicbus.
2018/08/12 at 7:36 pm #73312magicbusParticipant
Don’t know why this is so not obvious. I want to solo inputs/tracks, why is this so hard to figure out?
2018/08/12 at 8:03 pm #73313GCumbeeParticipantPAFL
2018/08/12 at 8:03 pm #73314peterlandersParticipantJust push the PAFL button on the desired strip.
2018/08/12 at 9:17 pm #73318AnonymousInactiveIf your PAFL tab is set to “AFTER FADE listen then you get nothing when you PAFL.
I assume that you do know you can route the PAFL [AFL] to the ALT out or even into the stage box AR2412 if so required.
Yes looking back you need to spend some time experimenting coming from an analogue mixer. In this attached pic the AFL is not turned on so you can hear the PAFL when the faders are down.2018/08/13 at 6:37 pm #73335airickessParticipantPage 61 of the latest Manual.
2018/08/14 at 7:49 pm #73356magicbusParticipantI may be asking this incorrectly.
I want to have multiple sources coming in and “solo” individual or several inputs. For whatever reason this is simply not obvious. Thx.2018/08/14 at 9:34 pm #73359BRSParticipantPAFL will normally come through the headphones. If you want to hear the solo’d channel(s) through the speakers, you’ll have to go to the relevant routing page to set the PAFL output to go out of your main outputs. (I’m away from my mixer so I can’t check exactly where it is.
Also if you want to hear more than one at a time (instead of just one at a time), you need to enable the additive option in the panel that NZDave screenshotted for you above.
2018/08/14 at 11:58 pm #73361AnonymousInactiveAlso you may want to have that solo’d signal coming out of seperate speakers.
On this TAB page 71/72 of the manual you can select the Alt out here as per attached pic.However.. and I have found sometimes after a lot of general experimenting with checks in boxes and testing what goes where I have had to RESET the QU quickly. And that often has worked.
2018/08/16 at 1:13 am #73391airickessParticipantI may be asking this incorrectly.
I want to have multiple sources coming in and “solo” individual or several inputs. For whatever reason this is simply not obvious. Thx.Page 61 of the latest manual.
2018/08/16 at 1:16 am #73392airickessParticipantDo you want to hear the solo channel through speakers or headphones? What is your setup? Are you using this in a studio setting or a live mix setting?
2018/08/16 at 11:25 pm #73406magicbusParticipantBoth live and in the studio.
2018/08/17 at 3:05 am #73408airickessParticipantThe PAFL button on each channel and output is the Solo button. It is routed to the headphone jack by default. You can also have PAFL routed to the ALT Out output (that also has a volume knob on the surface just below the headphone jack volume knob). That way you can hook up other speakers to that output (helpful for monitoring other mixes).
Page 61 of the Manual will explain how you can make the PAFL function in an additive or singular manner. It will also explain the other functions on the PAFL screen.2018/08/17 at 2:10 pm #73415magicbusParticipantI’m using the alt out. I understand that PAFL in the analog world often acts as a solo button. I’ve yet to be able to “solo” using the alt out or the Main outs for monitoring. Certainly in a live situation I’m interested in headphone only soloing. I’ve been on the road for several days, I’ll get back to it this weekend. Thx.
2018/08/17 at 2:13 pm #73416magicbusParticipantI’ve done the same. I had a channel that I could coming in yet refused to output. I reset and it was fine. I’m more then ok with the experimenting!
2018/09/04 at 9:14 pm #78344magicbusParticipantWell, I’ve still had no luck setting up the mixer so that I can “solo” channels. I also found out that the Alt Out does not carry with it the processing. From what I can hear.
