Qu-24 electrical noises during streaming
Forums Forums Qu Forums Qu troubleshooting Qu-24 electrical noises during streaming
This topic contains 95 replies, has 22 voices, and was last updated by Profile photo of Crosan007 Crosan007 2 hours, 36 minutes ago.
Viewing 15 posts - 76 through 90 (of 96 total)
  • #67232
    Profile photo of garyh
    garyh
    But don’t AMD based motherboards use Nvidia usb chip sets?
    #67233
    garyh
    I guess I should have said, don’t AMD based motherboards use non-intel usb chipsets?
    #67963
    Profile photo of jakethepeg
    jakethepeg
    Can someone give information on how to disable the USB 3.0 controller? I tried to, but the disable option is grayed out..
    #68121
    Profile photo of TrioAndreas
    TrioAndreas
    Hi!
    Unfortunatelly, I have the same problem with that noise on USB-B streaming. I tested 3 PC With Intel motherboard, one with USB3.0 and two with USB2.0, Win10-64, Win7-64, latest drivers, Qu16 firmware, and the result was the same: noise is always present. So, I guess that there is always problem with Intel chipset, no metter if it is USB3.0 or USB 2.0. I attach the sample of this noise (on 3sec and 53sec). I guess you all have the same problem?
    Could the Nvidia Chipset for USB resolve this problem?
    Damijan
    #68125
    TrioAndreas
    #68196
    Profile photo of Frank
    Frank
    Hi Anonymous,
    thanks for your two solutions:
    So the two options to possibly fix the issue:
    1. Disable XHCI in the BIOS if able to
    2. Disable the USB 3.0 Root Hub in Device Manager for Windows.
    1. solution is not possible with my laptop bios…
    2. solution is able to do, but after doing this, I have NO USB-ports anymore. So I cannot use the mouse and especially can not use the USB-dongle for the Cubase-DAW. They are completely disabled. Than again it is not possible to playback something from the DAW, where I get this incredible electrical noise.
    And I agree with you! It is not only a problem of INTEL! Both, A&H an INTEL should correspond to solve it, because the driver of A&H sets on the INTEL-driver. When INTEL driver changes, A&H should also have a look to adjust on the changed parameters, because there are a lot of INTEL-PC’s on this world but only “some” A&H-QU-mixers. And I fear the dinosaur INTEL will be stronger and not be willed to change… But perhaps A&H could change his ASIO-driver? I dont know enough about this but I really hope for a solution, because the USB-Connection for DAW recording and playback was one of the reasons for buying th mixer…
    #68198
    Frank
    And again: Is anybody able to NAME a working laptop, so I could try to buy one? With my Lenovo Ideapad it seems not to be possible… Tried to stop virusengine, WLAN, other backgroundprocesses, tried older A&H-driver, maked all INTEL-updates, nothing works… SOMETIMES it starts to distort, then I can change the driver-settings a little bit and it works again for some time, then distorsion starts again… It is no difference if I play from DAW Cubase or from Windows-VLC-Player!
    And does anybody know, if other A&H-mixers have the same problem or only QU-series?
    #68273
    Frank
    Or perhaps it is the only solution to try an Apple Macbook Pro for over 2000.-€ :-(, or are there the same problems?
    I think, I will give up, because nobody seems to be able to find a solution for every laptop and nobody can tell us, which are working… so I will do recordings on USB-Drive, this works, and copy this to the DAW later and remix on my desktop-pc at home…
    #68292
    Profile photo of Studiodawg
    Studiodawg
    Frank, I quit trying to find a way to record via USB to laptop and will simply employ the Qu Drive and then copy those tracks to my DAW PC to mix. I’m saving my pennies to get a reliable USB interface for direct to DAW recording. In defense of the Qu-16, it does allow for wide open sounding recordings due to the inherent headroom.
    #68294
    Profile photo of Giga
    Giga
    Apologies Frank, I meant to tell you which laptops work for me.
    2 Lenovo’s actually, a T61 and a T410. If you need more details just ask and I’ll try to find what you need. I may need some help cause my computerskills are nothing to write home about I’m afraid.
    Giga
    #68306
    Frank
    Hi Giga… I could find a Lenovo T410 used for buying… and you are nearly shure, that this will work with USB-B-Recording from A&H to Cubase Elements 9.5? I would really invest some hundred Euros more for a working solution. Which Windows do you use? 7 or 10? Home or Pro? How many RAM do you have installed? 4 or 8 GB? Which processor? i5 or i7? Which harddisk? And is it possible to install a SSD perhaps instead of “normal” SATA harddisk?
    #68323
    Giga
    Unfortunately I’m only sure it works with Studio One 2.
    It’s a 64bit W7 pro I7 @ 2,67 Ghz with 8 Gigs of RAM. It has a Samsung 840 EVO SSD.
    The T61 is older and less equipped but works great too.
    Good luck !
    Giga
    #68324
    Profile photo of [XAP]Bob
    [XAP]Bob
    What do you expect A&H to do? Intel USB3 chips can’t support proper USB2 behaviour.
    It’s like demanding that shell makes your Saab fly because Saab made some jets in the past and shell petrol is what you’ve used…
    Intel messed up their chipset… A&H software can’t do magic. An ECU mapping change won’t get 1000 horsepower from a three cylinder 400cc engine.
    #68325
    Frank
    Hi Giga, thanks for aour explanation. It is the same, what I could buy. only no SSD, but I could sell this on top, if normal HDD will not work… and of course, I didn’t mean USB-B-Recording, I mean USB-B-playback! This is the problem with this distorsions… the playback, not the recording! I don’t believe, that there is a difference between Cubase an d others, because I get it also with easy VLC-player… so I will buy this laptop and take it ONLY for AUDIO-subjects…
    Thanks for Your help! It’s a pitty, that neither INTEL nor A&H are able (A&H, because INTEL-driver-problem) oder willing (INTEL) to solve it…
    #68326
    Giga
    Ah ! Hold your horses ! I was only talking about recording as that is how I (sometimes) use this. How are you picturing you want to use the QU + laptop rig ? Maybe I can imitate that to double check for you. I’d feel bad if were to buy another useless laptop….
    Giga
