Forums › Forums › Qu Forums › Qu feature suggestions › Switch Aux to Matrix
- This topic has 28 replies, 10 voices, and was last updated 9 years, 8 months ago by GCumbee.
2013/10/30 at 9:57 am #35723ThomasLParticipant
In the german PA-Forum (paforum.de) a user suggested a “Switch Aux to Matrix” function. For us, and sure for many others, this would make a lot of things easier and the console even more versatile. We do a lot of smaller shows, mostly trade show events or others where you have only a couple of wireless mics, but a lot of loudspeaker zones, like delay lines, speakers different conference rooms etc. The QU16 is the perfect desk for that, but we have to solve the distribution thing via an external (Speaker-)Matrix. So – would it be possible for the DSP to switch Auxes Pairwise to become Matrix-Outs? Softwarewise this can’t be a big thing (I’m not the programmer, so it’s easy for me to say that 🙂 ), you wouldn’t have to change anything on the hardware itself.
So, just let us know, if this is an option – and keep up the good work 🙂
Thomas
2013/10/30 at 4:32 pm #35725woutertParticipantWhat exactly do you want to achieve?
2013/10/30 at 6:39 pm #35726ThomasLParticipantI would like to have some matrix busses on the QU – and I thought, that one possible way to achieve that without the need to redesign the Hardware would be the ability to switch busses between Auxes (fed from Inputs) and Matrix (fed from other busses). Sorry for the poor english 🙂
2013/11/01 at 12:43 pm #35771SteffenRParticipantThat would be a great idea.
In corporate events we don’t need that much aux sends but a lot more busses and matrices…2013/11/18 at 11:00 am #36117AnonymousInactiveI Really really would like to see this feature as we are always asked to give press feeds and i want to give them a matrix feed instead of just mixing a whole new mix for them on post fade… please enable this function!
Oh, and can we have a delay line option on the feed to please.. for delay stacks too…Thanks,
Dave
2013/11/21 at 4:47 am #36212eurobuieParticipantMatrix would be a very beneficial part of the console. a console of this class should have a couple of matrixs atleast.
2013/11/30 at 6:19 pm #36432LouParticipantDoesn’t switching the auxes to postfade, and set their mix all at zero acheive what you want? I don’t do that kind of thing so far, so why not?
2013/11/30 at 6:50 pm #36434SteffenRParticipantMatrix is a bus that is fed by busses not inputs
2013/11/30 at 6:52 pm #36435LouParticipantOh, right, duh. Too much turkey, brain cells asleep… 😉
2013/12/07 at 7:24 pm #36653AnonymousInactiveSo I sent all the faders to 0db and set them all to post fade. This was the make a version of a matrix send… However for some reason when on main mix the compression etc does not work on the matrix output… So that way around is pointless… And more suggestions or maybe even an update from A&H?
Thanks,
Dave
2013/12/12 at 10:35 pm #36813AnonymousInactiveBump… I need to switch the mix outputs to matrix outs so I can send press feeds and delay lines…!! Please update A&H.
Dave
2013/12/17 at 7:50 pm #36893AnonymousInactiveStill bumping!… Come on A&H… 🙂
2013/12/25 at 12:06 am #36993AnonymousInactiveBump
2014/01/25 at 3:39 pm #37412AndyParticipantThe QU16 is a small desk, which I bought to use it for smaller events, when I don’t want to carry my iLive. Groups or DCA’s were nice to have, but I can live without them. If I really need them, I use the bigger system.
What I miss, are one or two matrix outputs, to send signals to delayed speakers. Maybe the following could work and could be done easyly with a minor software update:
It is now possible to route a mono mix of both master channels to the alternate outputs. If it’s possible to add a independent volume control and a delay to each of the alternate output channels, we get two outputs for two mono delay lines, which follow the master fader. The controls only have to be at the touch screen, because if they are set, most of the time there will be no need to change the settings.
I think that could be an easy solution and would make the desk very useful for smaller corporate events.
Greetings from Austria,
Andy
2014/11/03 at 5:58 pm #42665SteffenRParticipantI still ask for group and matrix
group could be a fixed aux like others did itmaybe it is possible to configure the stereo mixes as Aux, Group or matrix
