Forums › Forums › iLive Forums › iLive troubleshooting › iLive-T112 White Screen on Boot issue
This topic contains 15 replies, has 12 voices, and was last updated by Ardian 2 months, 2 weeks ago.
2019/03/14 at 11:18 pm #82693
We are having the “white screen” issue when trying to turn on power to the iLive. I see that we should try replacing the cmos battery.
QUESTION: How do we access/find the battery?
Thanks!
2019/03/15 at 5:33 am #82698Located and replaced the battery. Still boots to white screen. Ideas?
2019/03/16 at 6:32 am #82721the same as what I experienced … I think there is a problem with the SBC board where it doesn’t boot, have I tried restarting the SBC board touchscreen?
You must be logged in to view attached files.2019/03/16 at 11:42 pm #82734How do I reboot the screen if it is all white? I can’t see where to touch.
2019/03/17 at 9:08 pm #82761When you have the white screen you have to first replace the backup battery on the mainboard who is located under the touchscreen.
unfortunately this is soldered to the mainboard. I removed it and soldered two leads with a battery holder for future easy replacement. i think it is a CR2032 but it is indicated on the old battery.
Then you have to connect a keyboard and monitor screen to the usb/vga-output.
When you power on the surface you have to enter the BIOS for the mainboard ( press F2 or F10 or something: it is indicated on the startupscreen)
go into the video screen settings and change the resolution to 800*640 (SVGA?) save and restart. touchscreen should be working normal.
Lieven2021/04/30 at 2:11 pm #101018Same problem here…
Questions:
When i enter the bios set.up it requires a password, what is the default password to enter bios set.up2021/12/08 at 12:13 am #104770If you remove the CMOS battery (which requires at least de-soldering it, but might be easier to just cut or repeatedly bend the leads to break them), I suspect the need for a password will be cleared so you won’t need it.
2022/06/07 at 7:10 am #107466I have changed the cmos battery and i did try to plug in keyboard and monitor,it does not detect the two of the device but the motherboard is just working fine so what is the problem?
2022/07/02 at 4:40 pm #107842Admin removed this post as this info is sensitive and should not be in the public domain.
Sorry. While we appreciate your contributions to this topic, we’d prefer not to have customers potentially tampering with the bios on our products.
2022/09/13 at 6:45 pm #108976Hello,
Could someone tell me how to open the backside fully to get to the battery out?!
I can see it, cause I opened up the highest backpanell, but to solder the battery out, I have to pull out the whole thing.Thanks for help…
Best wishes,
JörgAttachments:
You must be logged in to view attached files.2022/09/15 at 8:11 pm #109015Hello, is their anybody out there?
😂2022/09/16 at 5:28 am #109022Hello Jörg,
Yes, it is advisable to remove the whole board. In my case, the board (Fujitsu) was fixed with TX10 screws, but the CR2032 was not soldered but socketed. However, there are different versions of the board. Are you from Germany?
Many greetings
Bear
2022/10/13 at 2:26 pm #109495Hello
And thx. Yes from germany. We just had changed the bios battery but no result.
Lg Jörg2023/08/01 at 10:41 pm #113978I’ve had some luck with my T112 having previously had the white screen error.
I found online the manual for my SBC, the fujitsu one, & noticed the front panel conector wasn’t used in the ilive. I took a chance & connected a PC power switch to the front panel header & miraculously the SBC beeped into life! Hastily I connected a keyboard & monitor & noticed that the BIOS had reverted to it’s default state, so I replaced the battery, set the bios date & time, set the boot device to the CF card & after a couple of reboots & a couple of bios changes everything is now working as normal.2024/01/19 at 10:33 pm #118597Where did you connect the PC power switch to? I can’t see any indicators on the Fujitsu as to where/how to connect a PC power switch. Please advise if you can!
