De-Esser
This topic contains 29 replies, has 27 voices, and was last updated by Profile photo of trusted-tones trusted-tones 5 years, 5 months ago.
Viewing 15 posts - 1 through 15 (of 30 total)
  • #71913
    Profile photo of ianmoon
    ianmoon
    De-esser on an insert in a channel can be so much better than using EQ to compensate on certain mics such as headsets.
    Similar to how it functions on the D-live.
    Cheers in advance!
    #71954
    Profile photo of Zero
    Zero
    +1
    #72130
    Profile photo of Seven79
    Seven79
    +1
    #72770
    Profile photo of Subtower
    Subtower
    +1
    #72791
    Profile photo of looloosha
    looloosha
    Please 🙏🙏
    Sent from my iPhone using Tapatalk
    #72795
    Profile photo of Gerry Winkl
    Gerry Winkl
    Yes! +1! Even Yamahas M7CL has that. It’s really usefully!
    #72796
    Profile photo of lightingman117
    lightingman117
    +1
    #72800
    Profile photo of Rob
    Rob
    +1
    #72811
    Profile photo of Yann
    Yann
    +1
    #72912
    Profile photo of Lauren
    Lauren
    Yes, please. How is this not a standard feature on a console this new?
    #72953
    looloosha
    Yes. This need to be a thing.
    #73000
    Profile photo of Knacker
    Knacker
    +1
    #73451
    Profile photo of jeret356
    jeret356
    Really need this.
    #73480
    Profile photo of PatrickTylza
    PatrickTylza
    +1 – this is a MUST
    #73482
    PatrickTylza
    There actually is a workaround for this. SQ’s compressors do have external sidechain input so you can create your own DeEsser – all you need is an extra channel and a group.
    1. Patch the desired physical input to an extra channel, so you have two channels receiving the same input signal
    2. You route one of the channels to a group then the group to the master bus
    3. Route the other, second channel OUT of the master bus and all groups, so that it won’t come out of your master bus
    4. Apply HPF on the second, unrouted channel slightly below the “ess” freqency
    5. Pick up the “ess” frequency on the PEQ and boost it +15dB with a narrow Q (as shown on the attached picture)
    6. Turn on the compressor on a group where the first channel was routed and set it’s sidechain input to the secon, unrouted, eq’ed channel.
    7. Voila. The group comp is now your de-esser.
