Forums › Forums › dLive Forums › dLive troubleshooting › Buss Level Issue V.2.0
- This topic has 25 replies, 3 voices, and was last updated 2 months, 1 week ago by MixDizzle.
2024/06/15 at 7:10 pm #123086drshaneParticipant
Had an issue occur twice now where we have low or no audio going through busses after a power up. S7000 & DM64 hardware.
First time thought it was because operator loaded wrong show then immediately loaded correct show. Multiple show loads after without issue.
Second time console was powered up on correct show after virtual soundcheck the day prior. Audio through busses was 10+db below where it should have been. Rebooted console no change. Loaded different show, no audio through busses. Reloaded main show and rebooted issue cleared.
These were old show files that had been resaved with the new version. Will test next week after resetting the console to see if we can replicate the issue.
2024/06/18 at 1:45 pm #123200drshaneParticipantSo the issue seems to only happen on startup, sometimes there is no audio on busses other times it’s low, we’ve not been able to duplicate any other way. When it happens the only fixes seem to be either load another show and then back to the current show, then power down and back on the mixrack, or reset the mixrack. Leaving the mixrack on and shutting down only the surface seems to resolve the issue for us now…
2024/06/28 at 11:43 pm #123538crowleyParticipantS7000 and DM64 V.20 UPGRADE
I’ve had the exact same issues, the inputs signals all read as normal on the surface, the channel output is low on the meter and it’s output buss level is either non existent or very low. There was no pfl/AFL levels or output to headphones at all.
I’ve tried recalling a different show then coming back to the same show file and it was better and at least working, each buss in the chain seemed to even still cut the signal by 12dB or more at each step. Channel to Group was low, group to LR much lower, LR to matrix even lower again.
2024/06/29 at 12:48 am #123539crowleyParticipantS7000 and DM64 V.20 UPGRADE
Heard from A&H, they are working on it.
– for now you can do a hard system reset internally in the DM64
– Then reload 2.0 and that seems to fix it
– all show files will be lost that are in the Hardware surface will be ok. Back up shows
Maybe call A&H so it’s all under warranty
2024/07/02 at 6:57 am #123613Martin EhlertParticipantI think, I have the same issue with the bus level.
After I updated to firmware 2.0 coming from 1.98 there are not the expected levels on my busses. Whether mtx, group, stereo, mono, aux – in every bus the same low level.I tried to make a downgrade procedure to 1.98, then I went to 1.9A, then to 2.0.
It fixes my problem temporarily. But I wanted to be sure and did this procedure again – down to 1.98 – then to 1.9A and to 2.0.
Problems where again there with the bus levels.I did a hard reset with my mix rack . No chance to get the levels on my busses that are needed to have a correct signal.
It seems that there is a major problem with this firmware.
I decided to wait until a newer firmware than 2.0 is coming with bugfixes.
Then I will try again to go to 2.0 – and maybe install the RackUltra FX card.I´m on 1.98 and everything works fine for me.
***hope this could help you guys to not wasting time with useless try and error***
cheers, Martin
2024/07/02 at 11:57 am #123625RSParticipant@Matze
Maybe a hint about what MixRack/Surface combo you are talking about, might help the people in charge to narrow this down?
2024/07/02 at 8:23 pm #123643Martin EhlertParticipantthis is my DLive system
DLive C2500
CDM 48
Dante 64 Card
AES-10 Card
IP-8 Controller2024/07/02 at 9:11 pm #123644RSParticipantCan someone from A&H shed some light on this topic?
Got my UltraFX today and are about to install v2. Any advice?thx
2024/07/02 at 9:48 pm #123645Martin EhlertParticipant@RS
please let us know if and when your firmware update and fix card installation works
which setup do you have?
2024/07/02 at 10:05 pm #123647RSParticipantI am running a CDM32 plus Dante card with a Surface-less controller setup, containing 2 IP8s and a touchscreen.
I have planned the installation for Monday or Tuesday next week. But hope to hear back from A&H here before…2024/07/03 at 7:45 am #123652Nicola A&HKeymasterWe had a handful of reports of this issue and we are investigating. We’ll keep you all posted on this thread.
2024/07/05 at 2:56 pm #123690JonParticipantI have had the same problem with 2.0. No ufx-card and no sound at all on busses. My mixrack with ufx-card have worked so far.
2024/07/05 at 2:59 pm #123691Martin EhlertParticipant@Jon
Did you tried with RackUltra FX card installed?
greets, Martin
2024/07/05 at 4:19 pm #123694JonParticipantNot had the time yet.
2024/07/10 at 7:21 am #123802RSParticipantGot my UFX card and fw 2.0 installed yesterday. Until now it seems not to have caused any problems. Although I have only checked with virtual soundcheck.
