Forums › Forums › GLD Forums › GLD general discussions › Automatic mic mixing
This topic contains 16 replies, has 10 voices, and was last updated by Nicola A&H 8 years, 11 months ago.
2015/04/09 at 10:28 am #46694
How could I use this function ?
2015/04/09 at 10:55 am #466952015/04/09 at 11:19 am #46696Thank you very much! I did not know,..
2015/04/20 at 9:21 am #47189Very nice. I will try it out this week. Is it the Dugan algorithm?
2015/04/20 at 10:32 am #47190I tried this out yesterday in church using NOM mode and pretty much the default settings, although I turned on “Best Mic”. I was only using two radio mics and a fixed lectern mic. It all seemed to work pretty well, much better than my previous attempts using gates. There were one or two occaisions where it seemed a bit slow to open a mic, but it probably wasn’t too noticable to the congregation.
I chose NOM and Best Mic since that seemed to be the appropriate thing to do, but I might experiment with other settings.
Obviously the normal usage is for services where we have nobody running the sound and it has to “just work”. Of course if the service includes hymns then it needs someone to either turn down the sound, or have people mute their radio mics (or just not sing!). I did wonder whether I could do something like put a mic on the organ that is part of the auto group, but not routed anywhere, so that when the organ was playing it ducked all the other speech mics, but I’m not sure how sucessful that would be since people singing into their radio mics are pretty loud and would probably be treated as “best” and turn them on anyway.
I’d be interested in other people’s experiences.
2015/04/20 at 11:01 am #47191
AnonymousWow I take it this is only for the GLD?
I was told by a wee birdie (before 1.7 release) it was coming to the QU however that must have been incorrect. frivolous info at that time!
What a tease.
And to think I spent all of those years with the GSR24M and QU series with 12 x open lectern micsin live sound recording live to CD!? however,that’s life and progress.!
I’m not bitter, I learned a lot!
If I get my regular particular annual job back again,I will have to get a GLD just to get this feature!
Exciting!cheers
2015/04/20 at 1:17 pm #47196I did some bench testing the other day with the AMM on my demo GLD 80. I too found it slow on opening mics. Probably workable but slower than I would hope for. I have always found the gates to be plenty fast. Not sure why they didn’t set the same attack time on these.
2015/04/20 at 2:54 pm #47202Yes. I wonder if changing any of the settings would improve the opening time. e.g. would reducing the off attenuation affect it becuase it didn’t have so far to slew? Or perhaps reducing the hold time might make it more inclined to switch mics. I have a feeling, not proven, that it is slower when the “wrong” mic is already open. Clutching at straws here.
As you say, gates are plenty fast enough, but the problem there is setting the threshold, so it opens for the quietest speaker, but doesn’t open when someone loud uses another mic. So I prefer the behaviour of the AMM.
I’m guessing the D-classic wouldn’t be any better and it doesn’t seem to have the right properties for this application, but I’ll give it a go and see what hapens.
2015/04/26 at 11:47 pm #47533+1 it’s too slow at doing its job, you can clearly here it fade as its missed the first word of a new speaker. I think nom is a little quicker than the classic, but both far too slow.
I regularly use the waves Dugan auto mixer and it is outstanding, when I heard about the release of AMM I wondered if I had wasted my money. Absolutely not, worth every penny.
2015/04/27 at 12:23 am #47534Would like to see a maintenance release to improve the mic opening attack time.
Hello. Are we listening?
2015/04/27 at 7:10 am #47536+1 to faster attack. I’m going to attempt to use it on Thursday night with a panel of 7 people plus a chairman. Be interesting to see how it performs in that environment.
2015/04/27 at 12:47 pm #47548Hi,
Thank you all for the feedback regarding the AMM. Based on this information we have been working on improving the response time of the AMM and we are currently testing these changes.
Thanks,
Anthony A&H
2015/04/27 at 12:49 pm #47549🙂
2015/04/27 at 5:41 pm #47568That sounds like good news.
I had a trial run with my settup for the chaired panel this afternoon. Didn’t go well 🙁 I tried to use the Chair function, but I found that I couldn’t get the chair mic to even open unless I set the sensitivity higher, even to 10. But then I found that when the mike DID open it came on a decent volume to begin with, but then faded back down significantly. I found I could reduce this effect by reducing the Chair Duck Level, but even at -3dB the effect was still noticable. It was as if the chair mic was being ducked AS WELL AS all the other mics!. I thought, maybe, I shouldn’t have it both ON and set to CHAIR, but that isn’t possible.
So what am I doing wrong? This doesn’t seem right at all. In particular, if I set the gain sufficiently high so that the ducked level of the chair mic is acceptable, the peak when it first comes on is sufficient to push it into feedback, especially if the duck level is set to much more than -3dB.
I’d thought that this scenario was the ideal use case of the AMM, but it seems not. It’s better without the chair turned on, but I think I’m going to run the session manually to be sure.
Any suggestions?
2015/05/05 at 1:35 pm #47760I finally gave up on using AMM for the panel last Thursday evening. I couldn’t get the chair function to work at all sensibly and decided to run the whole thing manually after all. Which worked fine, but I had hoped that AMM would be more use. Disapointed.
Has anyone else had any success at all with the chair function?
