Forums › Forums › iLive Forums › Archived iLive Discussions › iLive Firmware V1.9 and new “OneMix” app news!
This topic contains 76 replies, has 39 voices, and was last updated by ryanp 11 years ago.
AuthorPosts
2012/11/12 at 10:40 pm #32037
Ignore my question – got through to the download page and seen release notes
Richard
2012/11/12 at 10:48 pm #32038Hooray!!
Thank you A&H !
Can’t wait to test this.IDR32
Dante card
Macbook pro 17
Ipad2 + mixpad
Aiport express2012/11/13 at 12:43 am #32039Is there a link anywhere that explains what some of these new features do other than the release notes.
Im very familiar with constant Q and proportional Q GEQs, but what are the attributes of the the Digi Q and hybrid GEQs?
Is the Didi EQ what I know as true response or perfect Q – adjacent bands with the same boost will sum flat without error …. and the hybrid is that half way between proportional and constant Q or is asymmetric with a proportional Q boost and constant Q cut etc. etc?
The multiband compressor is offered as a 3 or 4 band type. It looks like the crossover slopes are different (?) 6dB/oct for the 3 way (I assume for minimum phase error) and 12dB/oct for the 4 band. Is this correct?
FWIW – Im familiar with Dynamic EQs, but if you are not this may help -https://www.bssaudio.com/product_downloads/User_Manuals/dpr901iium.pdf
Peter
2012/11/13 at 2:24 am #32044Looks like the Multicast On or Off went away. Is that a concern?
CRJ
Oswego, ILT112 & iDR48
Sony F 1.73GHZ I7 8 Core
Win 7 Pro 500GB HD 8G RAM
TP-Link WR1043ND & Airport Express2012/11/13 at 8:14 am #32048Hey Peter,
For the differences between the GEQ try:
Help -> Help Content -> FX and Processing -> Graphic EQ.
The Slope of the Multiband-Compressor can be changed between 6dB, 18 dB and 24 dB by pressing the Slope-Button in the upper right corner of the multiband-compressor-window.By the way: The explanation of the Below-Threshold-Compression/Expansion in the link you posted is very good.
Cheers,
Mario
2012/11/13 at 8:19 am #32049quote:
Originally posted by PeterMFWIW – Im familiar with Dynamic EQs, but if you are not this may help -https://www.bssaudio.com/product_downloads/User_Manuals/dpr901iium.pdf
Thanks for that link!
2012/11/13 at 8:14 pm #32058quote:
Originally posted by Christopher JohnsonLooks like the Multicast On or Off went away. Is that a concern?
CRJ
TP-Link WR1043ND & Airport ExpressAH, does this mean it is on or off by default?
2012/11/13 at 8:34 pm #32059quote:
Originally posted by clarocqueAH, does this mean it is on or off by default?
I would bet big bucks on
iDR-48, T-112, Mixpad
College2012/11/13 at 8:51 pm #32061I read somewhere, probably in the release notes, that multicast went away because of few routers supporting it properly and metering is unicast now.
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad22012/11/13 at 9:00 pm #32062Has anyone else seen the update for Tweak on the app store? Mixpad updated fine (works a treat, very happy with the updates!), but it doesn’t seem Tweak has an update on the Australian or US stores yet?
Adam Biggs
T80 surface & iDR48
MixPad for iPad & Tweak for iPhone apps
Asus N61 Laptop (x2 wireless)
Windows 7 Pro 64bit
Mac Mini Server w/Mountain Lionwith Belkin PlayMax N600 HD router
Dante card tracking into Reaper with playback via FooBar (PC) or Presonus Capture/Studio One (Mac)2012/11/14 at 1:25 am #32072quote:
Originally posted by sraymondI read somewhere, probably in the release notes, that multicast went away because of few routers supporting it properly and metering is unicast now.
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad2I didn’t see that in the release notes.
CRJ
TP-Link WR1043ND & Airport Express2012/11/14 at 1:27 am #32073quote:
Originally posted by BiggsoundsHas anyone else seen the update for Tweak on the app store? Mixpad updated fine (works a treat, very happy with the updates!), but it doesn’t seem Tweak has an update on the Australian or US stores yet?
Adam Biggs
T80 surface & iDR48
Windows 7 Pro 64bit
Dante card tracking into Reaper with playback via FooBar (PC) or Presonus Capture/Studio One (Mac)No Tweak update in the US store. Just checked.
CRJ
TP-Link WR1043ND & Airport Express2012/11/14 at 4:50 am #32077quote:
Scott
iDR 32
iDR D-Out
MMO
CRJ
TP-Link WR1043ND & Airport ExpressFound it on the website…..firmware notes….
Multicast router capability no longer required: Wireless broadcast of iLive metering for MixPad and Editor no longer uses Multicast. This allows a greater choice of routers that should be able to work with iLive. The Multicast option on the iLive Surface has been removed.
Also in the editor notes….
Metering no longer multicast – Due to the inability of many routers to handle multicast correctly’, the broadcasting of iLive metering over the network has been changed and the multicast option removed.
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad22012/11/14 at 5:11 am #32078Thanks Scott… I missed it too.. need to go re-read – does this mean it should be on or off in the router now?
T112, iDR48 w/M-DANTE, PL10, MixPad, Editor
GLD-80 w/M-DANTE, GLD-AR2412, GLD-AR84 (2)
MacBook Pro, Mac Mini
Lion/Logic Pro/PT10
All latest versions/firmware2012/11/14 at 11:07 am #32084Hi Guys
The tweak app is slightly behind the main release – I pushed it to Apple for approval yesterday, the turn around is normally about 5 working days.
R.E Multicast it doesn’t matter you can turn it on or off, the metering is now sent using unicast UDP.
Cheers
Andy
A&H -
AuthorPosts
The forum ‘Archived iLive Discussions’ is closed to new topics and replies.
