wireless router to use with Qu-16?
Forums Forums Qu Forums Qu general discussions wireless router to use with Qu-16?
  • #36178
    Profile photo of jet1968jet1968
    Happy to report used the airport express with my Qu-16 last weekend and worked great. Went out into the car park 40 feet away and still had wireless control
    #36454
    Profile photo of Anonymous
    Inactive
    Hi Guys im in the UK id like to use one of my old talk talk routers with my qu 16 at the moment my ipad wont go far untill the signal drops out say 5-6 meters. I havent done any setting up of the router just plugged and played really, is there anything i could do to improve the range/performance
    Cheers Raoul
    #36751
    Inactive
    Appreciate the tip on the Airport Express. I have a couple of the old (small) ones around; will work perfectly in my setup.
    Drew
    #36760
    Cool, let us know how you get on 🙂
    #36817
    Profile photo of John-BJohn-B
    When I got my Qu-16, it had the V 1.01 firmware installed, a couple weeks later, the V1.10 firmware was released, so, I did the update at that time. I checked out the Qu Pad app, and at first couldn’t connect, so, I checked the DHCP on the mixer,enabled it, and everything was fine with my Airport after that. I also only use the 5GHZ band and hid the SSID, so, hopefully nobody’s phone will try & ping it. Works great! There sure is a lot of data going back & forth between mixer & and Qu Pad app though!
    #86751
    Profile photo of BarryBassBarryBass
    Hi all,
    I had a spare Ubiquiti Loco M2 so thought I could use it to connect a tablet to the QU16.
    So I set the Loco up as an Access point and can successfully connect to it. It does not have a DHCP server so cannot issue an IP address.
    So when connecting the tablet’s Wi-fi, I went into the Advanced settings and gave it the IP address of the Loco.
    Works like a charm! It proves one does not have to have a complicated wifi router.
    BarryBass
    #86781
    Just re-checked and found the DHCP server page in the Loco setup.
    So even better now – issues an IP address to the tablet and connects to the QU16, no problem.
    #86785
    Profile photo of GreenfingersGreenfingers
    Just to add my two penneth, I have been using a TP-Link AC750 Dual Band Wi-Fi Travel Router for the last year and a half without a hitch. Works everything with no connectivity issues – really cheap and very small – very handy!
    #87127
    Profile photo of JimmyJimmy
    Hi, I’ve been using an old Sky router for a couple of years now, with the QU 24, 32 and Qu-pac ever since my TP link one get damaged, it was literally plug n play. I keep it away from speakers etc, and I’ve had no problems even though I use wireless dmx for lights and up to 6 radio mics. Could be wrong but I think it has a better range than the TP, and basically being a small box shape there are no external aerials to get damaged.
