What Ipad is everyone using?
Forums Forums Qu Forums Qu general discussions What Ipad is everyone using?
Viewing 15 posts - 16 through 30 (of 42 total)
  • #60464
    Profile photo of KeefKeef
    Absolutely agree with MarkPAman – the Qu-Control app can do lots of things in addition to just levels. Seems it’s usefulness should be promoted a bit more.
    #60466
    Profile photo of J3phMPJ3phMP
    iPad Pro 9″ and or my iPad mini w/ Retina display. Both work extremely well. iPad mini a little small for my fingers when using the graphic EQ.
    #60470
    Profile photo of DavidDavid
    I use an iPad Air 2, which is fab. I have an original iPad 2 as a back up. I also use an Airport Express and it works a treat. I also use the 3.5mm stereo out of the Airport Express into the ST2 inputs on the QU16 and I can then stream music from the iPad to the QU16. That is a real bonus for me πŸ™‚
    #60517
    Profile photo of joel77joel77
    Thanks all for your input.
    I bought a refurbished ipad 2 with 64 GB for less than $200 and am about to get an Apple Airport Express. We’ll see how this works.
    Thanks again.
    Joel
    #60529
    Profile photo of debzdoodledebzdoodle
    Ipad 2 – it’s been rock solid for over 3 years now. I also bring my iPad mini to run lights which on occasion I have used with the QU PAC and it has also been great.
    #60543
    Profile photo of Mike CMike C
    I have iPad Air2’s that I purchased from the refurbished page at the Apple Store.
    I put them in these cases that let you hold them kind of like a painters pallet as well as propping them up at angle when you set them down.
    I also have cut some solid packing foam into angled blocks to prop them up at a steeper angle.
    #60548
    Profile photo of skippyskippy
    What is the name of that case? Pretty cool.
    #60558
    I got them from B&H photo.
    There are little expensive at $43 each but they do offer some decent protection and an easy way to hold them.
    B&H iPad case
    #60579
    Profile photo of FabFab
    Btw, how is qu-pad with an ipad pro 12.9″?
    How many faders per layer?
    Can we use the split view or something and control 2 differentes pages of qu-pad simultaneously?
    #60582
    Profile photo of BassistaBassista
    I use an Ipad Pro 9.7″ and a Xiaomi Router.
    No problems, works fine.
    #60583
    i’ve added this to my gear, just to be fast on stage……..
    https://www.adamhall.com/shop/gb-en/pro-audio/stands/iphone-ipad-and-ipod-stands/5572/sms-14-pro.
    #60702
    Tip: open qu-pad + qu-control simultaneously on the same device with the slide over.
    Works also with other apps like players or music app with airplay with the airport express
    #60711
    Profile photo of oleg_naumenkooleg_naumenko
    I use iPad Air Retina, iOS 10.2, very cheap 3com WL-524 access point (not a router), static IP addresses, on a Qu16. Works amazingly fast and robust. The only complain is it takes too much steps to start a connection, but I got used to it!
    #60722
    Profile photo of MarkPAmanMarkPAman
    “Tip: open qu-pad + qu-control simultaneously on the same device with the slide over.”
    Didn’t know about that. Now I want a newer iPad!
    Bother.
    #60796
    Just wanted to thank everyone who was helpful in this thread. I ended up purchasing a refurbished ipad 2 and an Airport Express. Spent some time yesterday getting things connected and figured out.
    Happy to report that everything seems to be working as it should. I can see this is going to be a great investment.
    Again, thank you. Much appreciated!
    Joel
