Stereo Aux follows pan rule
Forums Forums SQ Forums SQ feature suggestions Stereo Aux follows pan rule
This topic contains 42 replies, has 39 voices, and was last updated by Profile photo of Maxdrums Maxdrums 3 weeks, 6 days ago.
Viewing 15 posts - 1 through 15 (of 43 total)
  • #89449
    Profile photo of ianhind
    ianhind
    In the “mixer config page” there should be an “aux follows pan” rule.
    It’s very time consuming and frustrating to have to pan every channel, for every Aux while on IEM’s.
    eg. if I’m mixing IEM’s for a band with 6 stereo keys, stereo guitars, overheads, etc, and 8 stereo mixes, you currently have to hit select then pan on every channel, on every mix. This routine literally ends up being over 100 times once you finish them all.
    Should be quite simple to implement since the Buss routing already follows the pan rule.
    #89796
    Profile photo of Gregg Grey
    Gregg Grey
    +1
    #89802
    Profile photo of woutersnoei
    woutersnoei
    +1
    #89803
    Profile photo of JeroenAudio
    JeroenAudio
    Not for me please. I’ve often dealt with situations where artists like their voice on one channel only and have the music (band or tape) on the other. So I would like to pan independent from the main mix. And I don’t always have enough channels available to ‘double patch’ an input and use one channel for FOH and one for monitors.
    #89819
    Profile photo of MarkPAman
    MarkPAman
    I imagine that if it were to be included it would be an option.
    #89829
    ianhind
    yes, it would be an option. Similar to how a Profile/SC48/DShow would behave.
    #91080
    Profile photo of OlivierM
    OlivierM
    +1
    #91083
    Profile photo of Flo84
    Flo84
    hi,
    maybe a solution for you if you want the same pan settings on every mix (without your request) is to use the entire mix copy function?
    You can set pans on your first mix and past on the next.
    #91097
    Gregg Grey
    Definitly
    +1
    #91848
    Profile photo of Haniel Trisna
    Haniel Trisna
    +1 please.
    #91866
    Profile photo of Jline
    Jline
    +1 for me, I could see this being useful!
    #91947
    Haniel Trisna
    +1
    #92195
    Profile photo of Veniamin
    Veniamin
    +1 for global per aux option.
    +++1 for chanel local per aux send switching.
    #92273
    Profile photo of marcomedia
    marcomedia
    +1
    #92302
    Profile photo of trevorbeck
    trevorbeck
    Please add this feature. As a new owner of an SQ console, mixing 8 stereo IEMs last week was very time consuming having to individually pan things for each mix for 6 snapshots as per band requests.
    All could’ve been done with one pan on the master channel.
    Please make it an option per aux mix settings.
