Thanks for all the input. I will check to make sure the 48v is on and the preamp filter is on for that scene.
You will need to check the other scenes as well.
If you would go in and turn on that channels 48v then recall a scene that turns it off and then you recall the scene that needs the 48v on that mic channel with the preamp filter on the 48v would still be off.
Setting a global pre amp safe would do it but also block all the channels preamps, that may not be an issue if you are not changing any input gains with scene changes.
