Forums › Forums › Qu Forums › Qu general discussions › Confused with FX
This topic contains 18 replies, has 5 voices, and was last updated by [XAP]Bob 6 years, 11 months ago.
2017/04/16 at 6:39 pm #62937
Hi, (BIG Newbie). I seem to be confused re FX. I have set up 4 input channels. 1&2 are inputs from an AX8 (guitar). 3 is bass, 4 and 5 are vox. FOH (using a single speaker for practice) is OUT L, Aux 1 out goes via Snake return to Drummer. Aux 7&8 is to Shure IEM Transmitter and 9&10 are to studio monitors.
FX1 set to Reverb (Mix>return> (FX1) and FX2 set to Delay (mix>return) (Mix(9&10).
So:
1. I can get every input sound to FOH
2. Select FX1 (Channel layer ON, Master Fader SEL on) I can get FX1 applied to all selected channels through FOH3. Now MIX 9&10 selected, Channel 1&2 & 4 (vox) faders up. Guitar and voice heard through Monitor speakers (NO FX1)
4. I now want to apply FX2 just channel 4 (voice) for monitors only. I keep hearing the FX2 applied to FOH as well as monitors.I’d really appreciate a simple step through set of examples.
Thanks
H2017/04/16 at 6:40 pm #62938Sorry should have said this is a QU16.
H2017/04/16 at 7:02 pm #62939Turn down FX2 return on LR should help (or unassign FX2 from LR)…
2017/04/16 at 8:12 pm #62940Thanks Andreas,
What steps do I take to ‘Unassign’ from LR, and only send FX2 to MIX 9&10?
Thanks
H2017/04/16 at 8:32 pm #62941Page 22 of the manual should help.
On the desk, select Main Mix – hold the “Assign” key, press “Select” key of FX2 return.
Or in the App, there’s an “On” button above the slider, which needs switching off for L+R for that return.
But if you’re running your monitor mixes pre-fade (which is normal), just pulling the fader down for FX2 > Main, should do the trick.
2017/04/16 at 9:42 pm #62942Many Thanks for the info, but I’m, afraid I’m even more confused now.
I started again (reset board).
I have in Master Fader the SEL & LR led on. Channel layer selected.Faders 1&2 (from AX8) up, as well as vox on 3 & 4.
FX1=Reverb (Mix->Return) (FX1)
FX2=Delay (Mix-Return) (FX2)
Out to LR
Aux out 9&10 to monitors.I want FX1 on Vox channel 3 to FOH
I want FX2 on Vox channel 4 to Monitors not foh
I want guitar on channels 1 & 2 with no FX to both FOH and monitors.So with starting from Master Strip SEL & LR with faders on:
1. I press FX1 (all faders set at 0) I set master fader & channel 4 fader up – I hear FX1 applied only FOH.
2. I select MIX 9&10. faders up for channels 1,2 &3. I hear all in monitors ( as well as Vox 4 with FX1 in FOH)
3. I select FX2. increase Fader 3. Change FX2 to (Mix>Return) (Mix 9-10). I now have Channel 3 with FX2 in Monitor and FOH4. (I think as per your instructions) Select Master Strip SEL (This has been on all the time) and LR selected now still with Channel layer selected I press assign key (all SEL light up) and I press SEL key to FX2 Ret. Now when I press Assigh key all SEL light up except FX2 Rtn.
I still hear channel 3 with delay in FOH?
Sorry I’m just really rather confused.
H2017/04/17 at 7:18 am #62955Select the top of the three layers, then select LR, and look at the FX return faders.
2017/04/17 at 1:42 pm #62962Thanks Bob. Our ‘Sound man’ quit and I’m trying to fill his boots. Watched all the videos, read the manual. I can now just about spell ‘QU16’.
H2017/04/17 at 8:40 pm #62971That’s fine, see if you can find someone local to help you get started.
I’d rather train a musician to mix than a techie.
2017/04/17 at 9:29 pm #62974Thanks [XAP]Bob,
I’ll do just that, must be a local Church or venue with knowledge of Allen and Heath mixers.2017/04/18 at 6:58 am #62985Probably not actually – any mixer knowledge is good enough (though digital is probably marginally preferred).
The exact mechanics of each desk might be slightly different, but the principles are the same throughout. The QU series is particularly easy to jump to from an analogue system.
2017/04/18 at 1:56 pm #62995Many Thanks. That helps a lot in helping me identify where I can get help. I think there are one or two ‘mini studios’ here in town.
H2017/04/25 at 10:24 pm #63094Where are you located Hugh?
2017/04/26 at 12:03 am #63096Hi Joel77,
I’m suffering life in Sebastopol, CA. The weather, music, wine etc is just too much for a simple man. But I’ll take the hit for everyone else. 🙂2017/04/27 at 3:49 pm #63108I’m going to be in your part of the world next week, Hugh. My wife is from Sacramento and we love visiting San Francisco. Haven’t been in 3 years, so we decided it was time for another trip. For a rural Nebraska boy, I (surprisingly to me, at least) find SF an amazing place. The culture changes almost block to block! The architecture is beautiful. Love hanging out on the bay and just people watch.
Sorry, this has nothing to do with your question. Just got me thinking.
Joel
Glaser Audio Productions -
