Forums › Forums › iLive Forums › Archived iLive Discussions › Interesting email!
This topic contains 55 replies, has 26 voices, and was last updated by ddff_lv 12 years, 3 months ago.
AuthorPosts
2011/12/22 at 3:44 am #29399
If its not fully compatible out of the box, then it should be with an expansion card option.
We may find the next software update gives us a few extras. How can A&H justify not giving us USB recording when a cheaper model has it.
That 8 in 4 out 1U rack module would be very handy indeed.R72 & IDR32
MacBook pro
iPad 2
Airport express router2011/12/22 at 5:19 am #29400quote:
Originally posted by YeshuaCurious why they have a “DCA” button on a channel,
I am guessing that is for use in the assignment to a DCA. There is a little white line from the corner of the button to a red led as if its an indicator. Also, looking closely above the button it appears to say “Mute”.
I think it looks as though there are 2 banks of faders with 4 layers each. It appears to be 8 faders in the right bank (top pictures) and 12 on the left bank. Right top picture shows another set of layer buttons and right middle shows what would presumeably be three groups of 4 faders together.
I also noticed a routing select button near the processing strip in the upper right corner of the right middle picture.
Just my observations.
Kris
Indiana, USA2011/12/22 at 11:10 am #29505Seems to have 4 buttons per channel, just like the ilive range now.(select,pfl,mute,mix) The little red LED is the DCA mute indication.
Lieven
T112/IDR48/R72/IDR16/xDR16/2ACEcards/IPad1
Save a tree, eat a beaver2011/12/22 at 4:28 pm #29506quote:
Originally posted by Lieven DewispelaereSeems to have 4 buttons per channel, just like the ilive range now.(select,pfl,mute,mix) The little red LED is the DCA mute indication.
Lieven
Save a tree, eat a beaverThat might be it….
my iLive setup:
offline editor on mac, demo content on ipod touch
lol2011/12/23 at 3:46 am #29509Just some thoughts…..
I wonder if the dsnake could be ACE, just without the network bridging feature.
The DCA looks like an LED indicator but tied to the button (by a white line) which looks to be the Mute button also. So it doubles as a DCA assign?
Multiple MP3’s available that you can see along the left side of the screen. The finger is probably hiding something….(those rascals) []
Top of the screen has SigGen USB Audio (selected) Audio Dy?? and Direct Out. That third one almost looks like Dyss but I just can’t tell for sure. Or maybe Dyes for Dynamic eq system…. For those who have been asking for it. []
And I’d whole heartedly agree with every one 24×12 with 8×4 for a 32×16 stage capacity….no way to tell on the Surface I/O.
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad22011/12/23 at 7:28 am #29510I wonder if the on the touch screen the tabs say:
1. SigGen (signal generator)
2. USB Audio
3. Audio Sync
4. Direct outThats kinda what they look like to me….
also looks like on the playback portion, that there is a track timing bar that you can choose where on the track you want to be….they should add in a “This is where I’m at timer” along side that…for both playback and recording….
my iLive setup:
lol2011/12/23 at 8:38 am #29511Let’s hope that this means we also get a firmware upgrade in January
Multiband multiband…Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND2011/12/24 at 11:38 am #29517Ok. here is what i’ve benn told:
The new System is an total new system, not compatible with Ilive. Runs another protocol for digital audio also.
The processing is in the mixing desk, the Stage rack is just for converting analog to digital.
No editor, but an IPad App planned or already finished – i don`t know.
8 FX engines, same preamps as in the mixracks.So, we are looking at a complete new System that has nothing to do with our ILives and is designed to compete with LS9 and so on.
As i have been told also USB Recording and Playback is not possible with the ILives cause there are problems with the Linux used.
As i have to say – nothing comes from A&H directly – but from an good informed person – so we could be 100% clear @ NAMM.
2011/12/25 at 2:07 pm #29518So no USB recording for the ilive then[].
Well, it is possible to build a 24/12 with the existing range ( IDR16 + expander).
Only problem is that the expander can’t be used with the IPAD. Damn i really need A&H to fix that.
Hope the personal monitor system will be available for the ilive with an expansion card.Regards
Lieven
Save a tree, eat a beaver2011/12/28 at 1:59 am #29519Quote:Originally posted by albinOk. here is what i’ve benn told:
Quote:I can’t believe we are dealing with totally new non compatible system.
That is unforgivable A&H if it’s true, how could you justify that?
Why?
JimR72 & IDR32
MacBook pro
iPad 2
Airport express router2011/12/28 at 8:25 am #29520quote:
Originally posted by jimvoyagerI can’t believe we are dealing with totally new non compatible system.
Why?
JimR72 & IDR32
MacBook pro
iPad 2
Airport express routerJim, i have to disagree on that. A&H have to look forward and are trying to penetrate in the lower segment. They do that by offering a complete new system ( no possibility to mix and match like the ilive, and some sort off fixed configuration. ) to cut costs. Although the basic workflow/layout is copied in the new system.
There are not that much more possibilities to expand the ilive system as it is.
should we have another surface and another process rack in the ilive range?
I dont see the need for that. instead they have to fine tune the existing ilive software.Kind regards
LievenT112/IDR48/R72/IDR16/xDR16/2ACEcards/IPad1
Save a tree, eat a beaver2011/12/29 at 1:04 am #29521I think what Lieven says is probably right. In terms of the iLive system, how can you honestly get smaller then the r72 + idr16? And they still made that combination around $13-15k US (sorry not sure exactly on price). The only way to make an LS9 type of price range is by offering a new system or dropping the r72 price by $4-5k (which I would have preferred, but oh well…). I hope that the new system will offer many of the iLive features, but obviously it probably won’t have the expandability that the ilive has….I guess we’ll find out soon….
my iLive setup:
lol2011/12/29 at 12:09 pm #29522Maybe my language was a bit strong.
I’m not expecting fully interchangeable components, but I would hope it would be possible to exchange signals between the two systems without going analog.Jim[}]
R72 & IDR32
MacBook pro
iPad 2
Airport express router2012/01/03 at 3:49 pm #29638Many of these questions will be answered soon, just keep tight, but I am confident that you will be pleased with the outcome.
2012/01/03 at 5:33 pm #29642GLD series, I am excited to see what this opens up to future options….
JEFF FLOWERS
VOLCANO ADUIO PRODUCTS
SHEPHERDSVILLE KY-USA -
AuthorPosts
The forum ‘Archived iLive Discussions’ is closed to new topics and replies.
