suggestions
This topic contains 537 replies, has 136 voices, and was last updated by Profile photo of KB7981 KB7981 9 years, 10 months ago.
Viewing 15 posts - 301 through 315 (of 538 total)
  • Author
    Posts
  • #27734
    Profile photo of guyharris
    guyharris
    Participant
    quote:
    Originally posted by Biggsounds
    Maybe thats something that’s achievable with either Dante or MADI via ableton or the like?
    iDR32 mixrack
    MixRack for iPad & Tweak for iPhone apps
    Asus N61 Laptop (x2 wireless)
    Sennheiser IEM (for PFL)
    Dante card (soon!)
    We use Mainstage for this purpose.
    http://www.pianojam.nl
    #27735
    Profile photo of Clay
    Clay
    Participant
    First preference: Select mix via MIDI in Editor
    Second preference: Select mix via keyboard shortcuts in Editor.
    #27736
    Profile photo of Biggsounds
    Biggsounds
    Participant
    +1 on both of Claytons requests!
    iDR32 mixrack
    Dante card (soon!)
    #27737
    Profile photo of woutert
    woutert
    Participant
    Not only select channel’s Mix button, but also channel select!
    Indeed, both via Keyboard shortcut and MIDI.
    And or a quick select list to have especially “select” shortcuts to the most important channels (freely assignable of course)
    A HOME key for processing to return to the overview page (I’m not really a big fan of the superstrip, I like the overviewpage better, but it’s always a pain to have to hit that tiiiiiny little tab page, therefore, go back to overview via shortcut, Esc maybe, or BIIIG button next to the other tabs?
    Wouter
    My prayers have been heard, Dante is coming!
    #27783
    Profile photo of mjpruzin
    mjpruzin
    Participant
    External Input on the IP FX channels
    M. Jason Pruzin
    Sound Designer/Engineer
    Arkansas Repertory Theatre
    #27787
    Profile photo of scruffyd
    scruffyd
    Participant
    Doubletapping a frequency slider in graphic eq zeroes slider.
    #27840
    Profile photo of Clement-Bally
    Clement-Bally
    Participant
    hello,
    sorry for my English … I’m French
    I’d like to have an effect like “distortion”, a “on / off” independent on each band eq and the routing function in the software iLive editor. If possible thank you in advance
    #27841
    Profile photo of ddff_lv
    ddff_lv
    Participant
    briefly mute input on scene load if phantom status has to be changed.
    ddff
    #27844
    Profile photo of kentlowt
    kentlowt
    Participant
    quote:
    ddff
    Yes! To take it further a brief mute any time for any reason phantom status is changed even manually.
    112T/IDR48/IDR16
    #27848
    Profile photo of jimvoyager
    jimvoyager
    Participant
    Hi guys, for me as an R72 user, the ability to scroll along graphic Eq frequencies while in fader flip mode would be great. You could use the rotary encoder over the master send to do it. Also it seems crazy only having 8 frequency bands displayed at once when you have 3 faders doing nothing. Anything to avoid scrolling around to find a trouble spot.
    I love the system, keep up the good work.
    Jim[:D]
    R72 & IDR32
    #27882
    kentlowt
    Participant
    I would like for the software editor to be able to select to use a common area for user data so we don’t have to search around for the user files and move them to the next versions directory. A checkbox during the install procedure would be great. When an uninstall is done of a pre existing version it should ask whether or not to delete user data with default to no and it should ask if you want the common user data deleted as well with default to no.
    112T/IDR48/IDR16
    #27953
    Profile photo of Joe90
    Joe90
    Participant
    Q controls when in PEQ graph format. I think the graph format PEQ is great but its annoying when you have to change back to Param format to change the Q value.
    Cheers,
    Gary.
    iDR-32
    Motion Computing LE1700
    iPad – sometime soon
    #27961
    Profile photo of spart
    spart
    Participant
    Hello.
    I would like to have a “pan invert” on stereo input in the aux send or group send…
    And a width control on stereo input.
    And please please please, a great memory editor with “global paste”.
    denis
    #28011
    Profile photo of camhissey
    camhissey
    Participant
    How about, dont automatically assign all my channels to Main Mix outputs!!! every time i make changes to my mix setup, it reassigns everything to the main mix, very frustrating when you are using all the IP channels and have to change them again.
    #28034
    Profile photo of TheAVPro
    TheAVPro
    Participant
    Please have scenes recall “mix” selection, channels “freeze in layers” status, and bank selection. I am trying to have a one button recall to “basic mode” for non-technicians so that they can easily pull up a w/l mic or two with one button press.
The forum ‘Archived iLive Discussions’ is closed to new topics and replies.
