Qu-24 and Qu-16 as one console
Forums Forums Qu Forums Qu general discussions Qu-24 and Qu-16 as one console
This topic contains 24 replies, has 8 voices, and was last updated by Profile photo of DjBear DjBear 3 weeks ago.
Viewing 10 posts - 16 through 25 (of 25 total)
  • #68444
    DjBear
    Workin on a new project…
    #68451
    Profile photo of NZdave
    NZdave
    Good on you DjBear.
    Nice to see another person thinking outside the square.
    I have myself used multiples of QU in different combinations.
    Do you think its possible to put s simple hand drawn schematic up in this forum for other people to show them how it this is wired?
    Thank you
    NZdave
    #68458
    DjBear
    Yes, definitely. If you can make clean photo or scan on your schematic drawings (size under 500kb), you can put it up here. I’m also thinking on it, because more people asked me to show them how I wired my systems.
    #68468
    NZdave
    Sorry Lost in translation.
    I meant can you put your schematic of your system up on here?
    Cheers
    NZdave
    #68491
    DjBear
    Oh, I see. All right, I’ll try it. Untill that let me give some help to the “multiple QU users”. On my first picture the QU-24 channels are separated on 3 groups in MIX5-6, MIX7-8, MIX9-10. These MIX outs go in the 3 stereo inputs of QU-16. So we got 40 mono and 3 stereo inputs. On my second picture you can see an installation for a rock band. 32 channels are enough for them. On QU-24 the channels from 1 to 11 are the drum section, the grey knobs control the rack and floor toms. The next five channels (blue knobs) are guitar channels. The last 8 channels receive keyboards. On QU-16 the first 8 channels are for vocals. The second 8 channels (yellow knobs) are group faders. Ch9 is the bass, ch10 is also a mono group for kick, snare and hi-hat. Ch11/12 is a stereo group for overheads and toms. Ch14/15 is the stereo group for guitars, ch15-16 for keyboards.
    #68492
    Profile photo of rlandman
    rlandman
    Have you test to see if, with the new firmware releases, if these can be linking through Ethernet Cable? I know you can now digitally link the QU and SQ series…thanks
    #68493
    DjBear
    In April we may have a work for a symphony orchestra. That production needs 48 channels and more groups, so we are going to use two QU-24 for inputs and one QU-16 for groups. The whole console will be just 170 cm wide this way. (48ch analog consoles are often 2 meters wide or more.) Stereo MIXes (5-6, 7-8, 9-10) and main L/R outputs on both QU-24 will be the group outputs of different kind of strings, brasses, flutes, oboes, percussion, etc. Those 16 channels (8 stereo groups) will be controlled by QU-16.
    So that will be a 48 mono and 6 stereo inputs setup.
    #68494
    DjBear
    I haven’t tested through ethernet cable. We use Linksys 1Gbps wifi router for the connection.
    #68592
    Profile photo of Dkhand
    Dkhand
    I’m interested in learning about the ethernet link between mixer. But does that only works between a Qu and a Sq? Or can I do 2 Qu mixers together?
    Sent from my ONEPLUS A5010 using Tapatalk
    #68668
    DjBear
    My QU-24 and 16 are connected to the same router, but as I see, we can not make a master/slave connection between the two consoles. I gess there is no such menu on these softwares.
