Forums › Forums › SQ Forums › SQ general discussions › SQ-7 mute behaviour
This topic contains 16 replies, has 7 voices, and was last updated by Tobi 1 week, 4 days ago.
2024/04/08 at 7:27 am #121150
Hello! Is there a way not to mute Pre-Fader Aux Sends when MUTE button is being pressed?
We use Pre-Fader Aux for talent and production crew to communicate.2024/04/08 at 9:59 am #121162This is not possible in SQ.
You would probably have to use (an) additional channel(s) for this.2024/04/08 at 4:55 pm #121190Route your channels to a group and mute the group.
2024/04/08 at 8:12 pm #121193unassigns channel to a mix
2024/04/09 at 4:13 am #121202Thank you for your replies!
Muting the group is the same thing as muting individually. Unassigning the input seems to be working, but apparently you can’t unassign DCA. Am i missing something?
Unassigning inputs one by one is kinda non-intuitive2024/04/09 at 7:35 am #121204I really don’t think that muting a group is regarding the auxes the same as individual muting.
Best Regards,
Tobias2024/04/09 at 8:09 am #121205I tried and it’s the same
2024/04/09 at 8:47 am #121207Muting a group will not mute the individual Aux sends from the individual channel mixed to that group.
Just to be sure: We are Talking Groups here not DCA!
2024/04/09 at 10:29 am #121212Maybe we don’t understand exactly what you want to do yet.
As I said already, I would use two channels with the same input instead of one.
These could be “ganged” to do the same thing – except for mute and routing of course.
So the first channel is the one you can mute, while the second (for your Pre-Fader stuff) is not muted.
If you have to do the same thing with multiple channels, using a group would actually be the better choice – like nottooloud and Tobi already said.
This group sends the signal only to where it should be muted, while the individual channels in the group would be not muted.2024/04/09 at 3:04 pm #121218Muting the group is the same thing as muting individually.
I’d guess you’re talking about mute groups, where you see the mute buttons flashing. I’m suggesting routing to a group, which has a master you can mute. Those are very different things.
2024/04/10 at 3:52 am #121221Thank you for all the input!
Yes I was thinking you were talking about Mute Groups, sorry.
To clarify: I need to be able to mute inputs on main mix and post fader auxes, but not pre fader aux.
According to block diagram of SQ-7 mute button stand before PFL sends, so i think there is no way to achieve what i want here.
So i came to the conclusion that the best way to work around that is to unassign the input from the mix. \I ended up doubling the inputs i need to other small mixer we had around
Again, thank you for all the help!2024/04/10 at 7:24 am #121229> I need to be able to mute inputs on main mix and post fader auxes, but not pre fader aux.
This is exactly what can be achieved by using the 2 channels.
Like the keyboarder who always wants to hear his keyboard in his Inear, even if it’s muted in the mix.2024/04/16 at 12:42 am #121376If you only want to mute the post-fade sends and not pre-fade, assign the channels to a DCA. When that DCA is muted, all the post-fade sends will be too. If there are a lot of channels that need to be muted individually, you will burn a lot of DCAs, but it will do what you want.
Geoff
2024/04/16 at 9:51 am #121383> When that DCA is muted, all the post-fade sends will be too.
But in my experience also all pre-fade sends.
I think, the muting of a DCA is the same as using a mute group.
In both cases you mute all channels of the group – also including their pre-fade paths.2024/04/22 at 1:50 am #121523Assign the channels in question to a DCA. Instead of MUTING the DCA, just bring down the fader all the way when you want the Main and Post-Fader channels to go silent. The Pre-Fader mixes will still receive the signal.
Don’t forget folks, faders go up and down. -
