Forums › Forums › Qu Forums › Qu troubleshooting › iPad, router dropouts
This topic contains 15 replies, has 12 voices, and was last updated by Hercules123 8 years, 9 months ago.
2015/06/20 at 1:04 am #48849
We’ve even having a lot of trouble with dropouts between our iPad and the QU-16. The router is never further than 50 feet from the iPad and almost always has clear line of sight. It just seems like the mixer is really finicky.
I would like to replace our router with one that is known to work well with a QU-16. Any recommendations?
Thanks – JAY
2015/06/20 at 5:32 pm #48866We just started to use the IPad & an ASUS router. It works well with the iPad 4 generation & newer. The 2nd generation iPad wants to drop out a lot.
We bought router that has the a/c signal & the signal is strong & consistent.
I do know setting these routers up can be tricky. There’s no discussion about connections & setup.
I got an iPad Air 32gb at the Apple Store & got a refurbished for quite a discount.
There’s a learning curve when using the pad but it doesn’t take long.2015/06/20 at 5:39 pm #48867Make sure your update is the 1.7 & your router & pad have at least “n” for wifi signal. One of our engineers has an older 2nd generation pad & he’s having drop out issues.
Just a thought!2015/06/20 at 6:34 pm #48869For me an iPad 3 and an Airport Express (latest version) works reliable …
2015/06/20 at 9:37 pm #48870The last router we tried was (I think) an ASUS RT-AC52U. Our iPad is a new (2 months ago) Air version.
2015/06/29 at 7:19 am #49013I have a iPad 3 and an Airport Express 2nd version, I had a lot of trouble with other cheap routers
2015/06/29 at 9:02 am #49015I run an iPad Air and one of the 2nd generation Virgin Superhub routers which are made for Virgin by Netgear. Only time I have experianced dropouts are when there has been a lot of 2.4ghz activity in the room from mobile phones and similar devices, so I have set the router to 5ghz. But for the best part it has so far been a positive experiance using the iPad.
Distances vary from gig to gig, if I am doing FOH I can be in a theatre or just a mid to large function room.
2015/07/16 at 12:50 am #49308I have a ipad2 and zixel router, always I had problems with dropouts with QU-16, since 2 years, now I bought a QU-24 and the problem persists. I doubt if the problem is my ipad or router, because works in GLD I no have a problem with the same ipad and router, and Behringer devices works well too.
Any solution?
2015/07/19 at 3:28 am #49326The router recommendation page athttps://support.allen-heath.com/Knowledgebase/Article/View/847/201/recommended-wi-fi-router appears outdated. In fact there is an end-of-life announcement for the only one recommended:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1260-series/end_of_life_notice_c51-727739.pdfDoes A&H have any recommendations regarding routers for the QU series?
2015/07/20 at 11:48 pm #49340I had numerous dropouts at my event last weekend. Two times it disconnected with the router 12 inches away from me. Very weird.
I am using a Qu-Pac with an Ipad Air and Airport Express router.
Any thoughts?
2015/07/20 at 11:59 pm #49341It depends on whether or not you’ve set up your WAP so as to minimize the hits it will take in a busy wifi environment. There are many threads and discussions about this on the Pro Sound Web. I would suggest you go over there and do a search on the subject.
Or ask Andreas here…
2015/07/21 at 12:06 am #49342Or ask Andreas hereā¦
probably can’t suggest much, I rarely use the iPad for more than little monitoring setup. No problems so far, crossing fingers.
2015/07/21 at 12:09 am #49343Here’s a link to a thread currently discussing WAP security:
https://forums.prosoundweb.com/index.php/topic,155521.0.html
2015/07/28 at 11:49 pm #49585Ipad (1st generation) and Airport Express (version 2) have worked great for me on both
a GLD-80 and the QU-16. Make sure you have WAP and connect at 5ghz. Range good past 100 feet.
cheers,
Mike2015/07/30 at 6:02 pm #49629One more vote for the Apple Airport Express. My friend Mr. Dick Rees first put the bug in my ear last year but I was using a ‘mostly’ reliable Cisco. I still would get dropout though once in a while. I finally switched to the Apple 2-3 months ago and it was the best thing I did for my wi-fi set up.The range is much better and I have experienced drop out one time only due to poor positioning on my part. This is definitely a Buy once – cry once decision.
