Group Spilles
Forums Forums dLive Forums dLive feature suggestions Group Spilles
Viewing 6 posts - 31 through 36 (of 36 total)
  • #109462
    Profile photo of RSRS
    …, I use this feature all the time on other consoles.
    Out of curiosity, what consoles other then those from Digico offer this feature?
    Your post sounds like there is many others?
    #111197
    Profile photo of AnaAna
    +1
    #111202
    Profile photo of ParkerA1996ParkerA1996
    @tpaulding Plus, even though the DCA’s are non-processing, “not a real signal path”, it would be nice to see some use of the audio meter above them to ensure signal is passing through channels assigned to said DCA!
    #111252
    Profile photo of Matthew MixesMatthew Mixes
    +1
    #127067
    Profile photo of BrianBrian
    I’m just bringing this back up because I had to set up a new show file this weekend. I really missed having group spills during this process.
    Now I realize that turning the group spill functionality would remove one method that can be used to assign inputs to groups (because when you press the “Mix” button of the group, only the member inputs would show up and not all inputs – so you can’t add new inputs to the group by pressing their “assign” key). But all A&H needs to do is to include an “Group Spill” setting that can be turned on/off just like the DCA spill setting. (Plus there are other methods to adding inputs to groups – like the routing page of each input).
    I think ALL of us at some point are forced to burn DCAs simply to get this spill functionality when designing the fader layouts, but then it’s an awkward situation where you have both a group fader and a DCA fader. Having group spill functionality would allow us to stop using DCAs for this functionality and have a much more manageable/logical signal flow.
    So please A&H, add this much desired feature soon…..
    #127072
    Profile photo of JacobJacob
    +1
    This would be very helpful. Here’s hoping for 2.1… Who knows, maybe 2.1 can be a group heavy update by implementing group spill and group-to-group routing. Maybe…
    @Brian
    , I agree. After initial setup, most of the time when I’m assigning something to a group, it’s from the input side Routing page.
