Forums › Forums › dLive Forums › dLive General Discussions › 3 consoles
This topic contains 9 replies, has 6 voices, and was last updated by Jay 3 years, 10 months ago.
AuthorPosts
2019/02/27 at 11:34 pm #82280
Hey guys-
New to dlive system, but quite a bit of digital audio experience. Here’s my situation.
I have a C3500 with a dante card and a 64 input mix rack. I’d like to add a couple things but I’m having trouble finding clarity to what I can add.
I’d like to add a waves V3 card to run waves plugins off sound grid server, a c1500 for IEM console, and an additional c1500 for our livestream mix.
If I put a gigaACE card in the mix rack could I do all of this on the dlive system?
2019/02/28 at 8:05 am #82285wich mixrack? CDM or DM? they differ in expansion slots and redundancy features
you will need a GigaACE Card for every secondary surface, so every aditional C1500 needs a separate card
more information:
https://www.allen-heath.com/media/Understanding-Multi-Surface-ISS1.pdf2019/03/02 at 8:47 am #82324@jdubya if you put a GigaACE card in the stage rack & send your IEM & broadcast consoles from that card, and the Waves card in the surface slot you’ll be good. Just make sure you set roles for each & gain track everything
2019/03/06 at 5:15 pm #82433@biggsounds will the gain tracking work on any surface/mixrack in the system? I’ve seen it setup for using 2 surfaces with one mixrack. Wondering if it’ll work in a multi-surface/mixrack setup if roles are set accordingly.
@jdubya we run a DM64/s7000 for FoH and a DM0/s5000 for monitors with an option to split all channels out via Dante to DM32/c3500 for recording or steaming. Patching everything is pretty straight forward on the I/O pages. So far so good.
2019/03/06 at 6:47 pm #82434It is also worth noting that C series desk and C series mixrack only has one card slot in each.
2019/03/07 at 3:57 am #82444Thanks guys!
I’ll have to validate which mixrack I am working with but You are confirming what I thought. Time to get to work I suppose!
2019/03/07 at 8:14 pm #82484the system can provide 4 surfaces with one DM rack (every slot holds a GigaACE Card)
and regarded to the slot count only 2 surfaces with a CDM rackbut every surface has extra slots for additional networking cards like Dante, MADI or Soundgrid
2019/03/07 at 8:51 pm #82487So I have a CMD console….which complicates things. I posted a flow chart of what I was thinking with consoles and cards and all, but I have the impression that this doesn’t work. I can’t pass GigaAce from one console to the next if I put the GigaAce card in the console correct?
2019/03/07 at 8:55 pm #824882019/03/08 at 5:24 am #82495I’ll give you one more option, but it depends on your exact needs. I use it regularly, A&H has confirmed it works, but it technically isn’t a directly support configuration.
If you don’t need Audio I/O at your additional surfaces, you can treat it just like Director and connect the ethernet (not GigaAce) on the additional surface(s) to the Mixrack network connection and you have full control as another role. Pick up your audio (including headphone) off the MR or another surface with a GigaAce connection.
I’ve had running:
– DM64, with GigaAce card and 2x DX168’s
– tied to S5000 via onboard GigaAce, with Wave v3 and Dante cards
– IP8
– ME Hub + ME1/ME500’s
– 2 Directors (1 wireless)
– SQ6 tied to DM64 GigaAce
– C1500 tied to DM64 network (no audio, it came off DM64) and was effectively used as an extension of the S5000Musical theatre, 40+ wireless + live orchestra
Could the chose to remove the ability to run a surface like this? Sure. Would they?
Jay
AuthorPosts
You must be logged in to reply to this topic.
