Hi Sholasleek,
yes, you will have then 24 outputs. The AR2412 for example has 12 outputs. If you were to daisychain an AB168 from the AR2412 you add another 8 outputs. That would max out the limit for the 48kHz stageboxes (40in 20out). So, toghether with your local outs you would then have 32outs. I attached the i/o connection sheet from A&Hs knowlegde base.
Hope that helps a bit
Cheers
André
You must be
logged in to view attached files.
