Forums › Forums › SQ Forums › SQ general discussions › SQ Firmware V1.3.1
This topic contains 17 replies, has 11 voices, and was last updated by csumi 5 years, 3 months ago.
2018/12/07 at 12:48 pm #80640
Registered users will be receiving emails shortly, but if you haven’t already heard – SQ Firmware V1.3.1 is now available to download.
https://www.allen-heath.com/key-series/sq/sq-software/This includes improvements to USB recording and network control.
Please refer to the release notes for full details.
Thanks,
Keith.2018/12/07 at 3:36 pm #80646Thank you Keith, I’ll install asap and test this tonight gig!
2018/12/07 at 8:38 pm #80659Just installed, will be testing multitrack recording to a Samsung T5 500gb SSD at tonights show.
Crossing fingers these bugs have been squashed.
2018/12/08 at 2:00 am #80662I installed 1.3.1 this morning and I am happy to report one successful gig with reliable network Ipad control without any freezing issues. Thanks A&H team! This is such a relief! I’m more hopefully to see continued successes now moving forward. Ironic for you to release the firmware update on a Friday, but I’m content and grateful despite the timing. In my case, it came just in the nick of time.
2018/12/08 at 1:33 pm #80675Unfortunately I’ve found a bug in the mix stereo aux: they don’t change the naming of the single aux send in this section when you move from a scene to another, you need to stereo link and apply to “update” and display the correct aux name.
I’ll open a ticket!2018/12/08 at 4:06 pm #806782018/12/10 at 1:56 pm #80715Thanks @fabry – We have noted this as a bug. It’s not unique to V1.3.1, and presumably has not been thought of as an issue previously as mix config is saved at show level, so it’s generally set before storing or making any changes at scene level.
Cheers,
Keith.2018/12/11 at 2:38 pm #80759Hi All,
Due to an inadvertent flip in the DEEP Peak Limiter 76 black-face and silver-face GUI’s, there is a V1.3.2 available now.
This was a very (very) low risk change and only required a single day of testing. Hence the ultra rapid turnaround…
There are no other differences between V1.3.1 and V1.3.2.Thanks,
Keith.2018/12/11 at 3:15 pm #80764Thanks Keith! I have only been checking the troubleshooting forum to see if there was any updates on the USB streaming issue. I had no idea 1.32 was out.
So far so good on the streaming front. Fingers crossed. Thanks A&E for all your hard work and getting this firmware out super quick.
2018/12/28 at 10:13 pm #81124Hello
I have v1.3.0 on my SQ5 and seems that I can’t upgrade to v1.3.2. I can’t find v1.3.1 anywhere on the A&H website. Any suggestions what I can do?
Best Regards
TT2018/12/28 at 10:51 pm #81125You should need 1.3.1 to upgrade. I did one the other day from 1.2.2.
Probably not correct on the thumb drive or something else. Follow the instructions exactly. Unzip the file. Put the .bin file on the root level. No other versions showing. Make sure you downloaded the correct version. There is a different one for each console size.
2018/12/28 at 11:25 pm #81128Hey
Thank you for the reply. Seems I have forgotten to unzip the file.
Best
TT2019/01/10 at 6:07 pm #81329Hello Everybody!
I don’t have SQ6 1.3.1 firmware. I forgot download the firmware. Now only 1.3.2, but I don’t upgrade 1.3.0 for 1.3.2.
Please help me.
Thank you
2019/01/10 at 7:10 pm #81330Odd as I upgraded from 1.2 to 1.3.2 without any problems.
You did remember to unzip the file and copy the .bin file to your USB ?
2019/01/10 at 7:27 pm #81331Yes, I unzip the file and copy the SQ-6UPG_1_3_2r3100.bin the USB root.
The desk Firmware window “no image found”
1.2.2 firmware & 1.3.0 firmware is see in the window.
