Qu 32 Recording USB into DAW Windows Reaper
Forums Forums Qu Forums Qu general discussions Qu 32 Recording USB into DAW Windows Reaper
This topic contains 31 replies, has 5 voices, and was last updated by Profile photo of Mike C Mike C 3 years, 4 months ago.
Viewing 2 posts - 31 through 32 (of 32 total)
  • #97391
    Profile photo of volounteer
    volounteer
    @mikec
    hard way? maybe
    but it does get done
    and we have to do it with the volounteers we have
    they did an aamazing job to get us from nothing to where we are now with livestreaming
    and the main video operator is just going into HS
    alt out is not a good choice
    the livestream needs some extra mikes not used live as the organ is already loud acoustically
    and we tweak the balance of everything specifically for their use
    #97403
    Mike C
    You do realize the ALT OUT can be routed to ANY mix out of the mixer.
    If I’m not mistaken your using MIX 7 8 for live stream.
    Go to the IO routing menu, under the surface tab, ALT OUT select the mix you want the
    ALT OUT to be.
    The ALT OUT level knob under the headphone level knob.
