Compressor on FX returns
Forums Forums SQ Forums SQ feature suggestions Compressor on FX returns
This topic contains 15 replies, has 14 voices, and was last updated by Profile photo of Ma Ma 8 months ago.
  • #107160
    Profile photo of litti
    litti
    This is the feature I miss the most from my GLD days, when I could also route the Fx send to a “normal” fully processable stereo channel. When I owned the Gld I used to compress the return of the delay or echo Fx in order to keep its level always below the main source easily
    #108990
    litti
    Am I allowed to bump this? If not, I apologize and will delete
    #108994
    Profile photo of KeithJ A&H
    KeithJ A&H
    Moderator
    @litti
    (bumping is fine 🙂 )
    This is a tricky question as the current routing architecture only allows for FX engine outputs to be sent to FX returns, output sockets (analogue or digital) and insert returns.
    Adding the option to input channel sourcing to also be able to receive this signal may or may not be possible and would require development and test time to find out.
    Unfortunately it’s not a case of ‘it can be sent from A to B, so it can be sent from A to C’ with one change to a line of code…
    So if there are others who really want this too, it might be something we look into.
    One quick and easy workaround however, would be to run one or more FX returns through a group and make use of the mix processing there.
    Thanks,
    Keith.
    #109014
    Profile photo of peterm2
    peterm2
    +1 I also like this feature!
    #109139
    Profile photo of creal
    creal
    I completely agree, it’s a basic feature that would be very welcome.
    As other workarounds for the meantime, we can also use insert FX on an Aux channel, or send an FX bus on another FX bus.
    #109141
    litti
    @keithjah,
    thanks for the reply, I know it’s not easy but I hope this feature will be implemented some time in the future.
    @peterm2 and @creal thanks for backing me 🙂
    #109162
    Profile photo of Brian
    Brian
    I can definitely see where this would be helpful!
    +1 to the list.
    #109188
    Profile photo of Tobi
    Tobi
    +1
    #109268
    Profile photo of lightingman117
    lightingman117
    +1
    #111833
    Profile photo of Proper Audio
    Proper Audio
    +1
    I’ve been using side chain compression on delay returns since the analogue days. My workaround on the SQ is basically sending the FX return into a group (wasting a group…) in order to enable SC-compression.
    I’d rather have an FX buss that allows for SC-compression on the return, using the input signal of said buss as a SC input for the return’s compressor.
    Should that cause routing or coding issues: I’d be happy for a delay/echo FX unit with internal SC compressor / ducker with variable timing instead.
    #112866
    Profile photo of ptrcmrcl
    ptrcmrcl
    +1
    #112898
    Profile photo of SimonVB
    SimonVB
    +1
    #112901
    Profile photo of alberto.irrera
    alberto.irrera
    +1
    as Proper Audio said, SC compression on fx returns is often useful
    #112914
    Profile photo of nottooloud
    nottooloud
    +1
    I’ve been sending the delay back to itself to get full regeneration for dub reggae. There’s unfortunately no way to put a limiter on the send *or* the return, so the only safety is limiting on the master output.
    #113644
    Profile photo of Seth
    Seth
    +1 I’d love to be able to sidechain compress my vocal verb and delay to the dry vocal.
