SQ5 v1.3 Digital Noises on Multitrack Recording
Forums Forums SQ Forums SQ troubleshooting SQ5 v1.3 Digital Noises on Multitrack Recording
  • #80855
    Profile photo of TrangHoTrangHo
    Just happen again. I got the digital noise right after reboot and restart SQ6. I also tried to switch between USB B and SQ-drive but didn’t help neither. Again unplug in/out usb fix the issue
    #80863
    Profile photo of KeithJ A&HKeithJ A&H
    Moderator
    Hi @trangho200804gmail-com ,
    Please try the following:
    • Re-installation of the latest firmware from a fresh download (sometimes downloads can become corrupted)
    • A hard reset of the SQ. To do this, first back up the desk by saving a show to USB, then hold EQ ‘In’ and ‘HF’ keys whilst powering on the desk
    • Test with another USB cable (ensure it is USB 2.0)
    • Test in a different port on your computer
    Then, if you are still having an issue, please contact us using support.allen-heath.com and we will look into what could be causing this on your system.
    Thanks,
    Keith.
    #80972
    I did hard reset, download and reintalled 1.3.2 but still got noise every time SQ6 rebooted. I have to unplug and plug back in usb cable to fix it.
    same set up but nerver happen with build 1.3.0
    #80999
    Changed USB cable, different usb port, got same issue.
    #81000
    Profile photo of ronnie_pronnie_p
    Have you tried a different computer ? I have a ( old ) laptop that makes all kinds of noises , other laptops don’t have this problem
