Forums › Forums › Qu Forums › Qu general discussions › QU-SB Flight Case
This topic contains 28 replies, has 15 voices, and was last updated by TylerJ 6 years, 10 months ago.
2016/11/01 at 3:34 pm #59001
Hi,
I am trying to source a shallow 4u flight case that will fit my QU-SB.
It’s tricky because the QU-SB rack mount angles the front and the bottom edge of the QU-SB projects out 38mm from the flight case screw plate. Most flight case front covers won’t fit on with the QU-SB installed.
I thought this SKB might work but the dimensions show that the front cover is 10mm too shallow inside so it wouldn’t be possible to put the flight case lid on. https://www.skbcases.com/music/products/proddetail.php?f=&id=791&o=&c=114&s=
Has anyone found a shallow flight case that definitely fits?
it’s a class unit BTW…Andy
2016/11/01 at 4:39 pm #59002I considered getting one with a deeper lid made by Swan Flight who’ve provided several of my cases before, as it really does not add much to the cost. However in the end, I found another solution:
My QU-Pac, which has the same angle on the front I believe, is in a “proper” ply/aluminium case, but I unbolted the rack strip & fitted it the other way around. It did make fitting the unit a little more fiddly, but once done it works very well.
2016/11/01 at 4:50 pm #59006You could try spacing the rack back from the rails?
2016/11/01 at 5:51 pm #59011Interesting solutions. Do you have any photos?
2016/11/01 at 7:21 pm #59013I’ve just ordered the SKB 4u shallow roto rack, I didn’t check clearance…
2016/11/02 at 11:20 am #59038@GaryW – Hopefully you can work something out with that SKB as it’s a nice looking case.
@[XAP]Bob – Do you mean install spacers so the QU-SB rack mount ear are screwed in from the back of the flightcase rails to gain the extra 10mm or so?
2016/11/02 at 1:23 pm #59039I own the QU-PAC and I use this case which works perfectly. If the QU SB does not protrude any further forward than the QU PAC, then it will work. The rack is very shallow and allows for easy connection to the back. The quality is surprisingly good and I have been using mine regularly since I got the QU PAC over a year ago.
2016/11/02 at 3:35 pm #59040That case looks exactly like this ‘Spider’ branded one here in the UK. I think that will do nicely.
2016/11/02 at 9:30 pm #59047Hi, Thomann has One that worked for m’y QU-SB
https://www.thomann.de/gb/thon_rack_4he_eco_ii_compact.htm
Cheers
Sent from my iPad using Tapatalk HD
2016/11/02 at 11:05 pm #59052Yes, I do.
I don’t have one, but it’s something I’ve done with other gear occasionally
2016/11/03 at 4:57 pm #59068I’m still waiting to find the SB rack ears here in the US
2016/11/03 at 5:41 pm #59070Really, it’s amazing they aren’t there yet as a pretty important item..
2016/11/03 at 9:28 pm #59076Rob,
Can you get a Sweetwater rep. to special order them for you? I have always found them to be most helpful.
2016/11/03 at 11:21 pm #59079It seems to be the case that there just aren’t any in the US yet for some reason.
2016/11/04 at 1:46 pm #59088A bit of an extreme solution but Thomann in Germany would ship them to you!
https://www.thomann.de/gb/helpdesk_shipping.html?country=USA
