good that we could help!
Ethernet adaptator to a regular ethernet plug of the router with an xover cable
the crossover cable should not be necessary in this case,
only for direct connection without any switch or router (if the IP adress is fixed)
and if you are using a different device (server, managed switch) as dhcp server you don’t need a router
