Forums › Forums › Qu Forums › Qu feature suggestions › Wired Or Wireless?
This topic contains 15 replies, has 6 voices, and was last updated by SteffenR 4 years, 1 month ago.
2016/04/13 at 3:33 pm #55052
Hey all. Being a user of the QU 32 and Qpac, I much prefer the Faders being something I can Move and touch. In some instances the wireless control and the compact size of the QU-Pac cant be beat. I am also not a huge fan of WI-FI only because of potential problems of interruption of the signal. So the suggestion If possible:
A direct connection from my I-Pad to the QU-Series via the USb or network port. I also saw some potential new product at a recent D-Live event. one of those little fader banks that could connect via the network jack. Something to have in those time when WiFi just don’t work.Thanks for listening.
2016/04/13 at 4:19 pm #55053Hmm, tried this:
Apple Lightning to USB Adapter -> Powered USB Hub -> Apple USB to Ethernet Adapter
Then from ethernet adapter either into router which also distributes IP addresses via DHCP
Or using fixed IP addresses on both iPad and Qu and connect via Xover cable.2016/04/14 at 8:02 am #55067Well… the android app supports external fader banks via USB OTG.
And some tablets have ethernet ports as well…So you could combine those two.
2016/04/14 at 8:28 am #55072
AnonymousSo my question on reading the link Andreas posted… https://www.gottabemobile.com/2014/08/28/how-to-connect-an-ipad-to-ethernet/
Can I run 2 ipads into the hub wired to QU?
A FOH virtual mixer hard wired via ethernet.
I do like the wireless however have found it slow (to catch up with data) scrolling through channels.
Waiting for the ipad to load the names of channels etc.
If I was positioned at FOH with 2x iPad pros hard wired as a FOH mixer, this could be really great!?2016/04/14 at 8:46 am #55074For the ethernet communication its the same whether you’re running through WiFi or cable.
If you’re using a hub/switch you’ll need to assign unique IP addresses manually (i.e. Subnet 255.255.255.0, Qu: 192.168.1.100, iPad1: 192.168.1.101, iPad2: 192.168.1.102 etc.).2016/04/14 at 9:14 am #55077
Anonymoushmm ok Thanks
So why a crossover cable?
Is that because of computer to computer? like the internet sharing days of win98?2016/04/14 at 9:49 am #55080Not sure if Apple’s Ethernet Adapter is able to auto-sense (doubt the Qu’s LAN port does it), so you’ll need a crossover cable to connect both directly to eliminate the hub/switch (indeed, as we did in old Win9x days). If you plan to run multiple cabled iPads you do need a switch and regular cables.
2016/04/14 at 3:21 pm #55087Andreas, very interesting idea. Thanks much for sharing. I will be giving this a try…..
Jeff
2016/04/14 at 3:41 pm #55089Most things autosense nowadays – it’s my expectation (particularly since it’s required on GigE)
2020/02/20 at 10:17 pm #89752Hello AndrĂ©a i just bought a qu sb for my home studio and i think i misunderstood your post because i thought that i didn’t need internet to conect an ipad to the qu sb…
What i tried is
ipad > usb adaptator > usb ethernet hub > xover cable > qu sb
qu pad asked for an ip adress it was 192.168.1.100 i clicked yes and it told me connection failed…
I am really a jerk in computer please show me the way cheers !!2020/02/21 at 3:01 pm #89771wich device is doing dhcp?
if non, you need to add a router or access point to provide dhcp adressessee the quick start guide chapter 6
https://www.allen-heath.com/media/Qu-SB-Getting-Started-Guide-AP10287_2.pdf2020/02/22 at 2:19 pm #89789Thanks Steffen i’ll have a look on tuesday at home and i haven’t a router in the chain that’s why, but i thought i can use it without an internet access….
Cheers.2020/02/23 at 5:50 pm #89807the router is not there because of the internet access…
since the QU-SB has no display it is hard to set a fixed IP adress
so you should start with a dhcp server…
the easiest way is to add a WiFi router to the setup2020/02/23 at 8:20 pm #89813Ok thanks i am a bit lost with this kind of gear ,)
2020/02/29 at 12:03 pm #89917Everything is ok now..(THANKS STEFFEN)
One little thing that maked me crazy the qu sb ethernet cable as to be plugged inside a regular ethernet plug inside the router and not the internet one. (THANKS KEITH)
As for the harwired ipad :
Configure the router as describe in his manual
Connect the qusb with rj45 cable to a regular ethernet plug of the router (not the internet one)
Connect your ipad to an usb adaptator (that has a plug for power supply)
Usb adaptator to ethernet adaptator
Ethernet adaptator to a regular ethernet plug of the router with an xover cable
Done… easy but sometimes silly things goes in the path….. -
