vu-meters on DCA
Forums Forums SQ Forums SQ general discussions vu-meters on DCA
This topic contains 15 replies, has 6 voices, and was last updated by Profile photo of jb07 jb07 3 years, 4 months ago.
  • #96053
    jb07
    Why are there no led vu-meters on the DCAs?
    #96054
    Profile photo of Mike C
    Mike C
    A DCA group has no audio actually flowing through it, it is control only.
    #96145
    Profile photo of Dave Meadowcroft
    Dave Meadowcroft
    That doesn’t mean there shouldn’t be any metering. Anything that controls/groups audio should have metering regardless of whether it’s a real or virtual path.
    Other manufacturers do this by showing the highest level of any source assigned to the DCA group which makes perfect sense to me.
    #96147
    Profile photo of SteffenR
    SteffenR
    Dave… we discussed this already… a long time ago…
    and one statement from Keith was to not display any level as long as it could be wrong in regard to the real level
    If you solo a DCA you send the signals to the solo bus and now you have metering that is correct, it shows a sum of the DCA members then.
    I will try to find the old topic….
    #96150
    SteffenR
    I found at least three topics…
    Metering on DCA channels
    Metering on DCA faders
    DCA Meter
    #96152
    Dave Meadowcroft
    I’ve just read those and there are some interesting points.
    If it was highest level (MAX of all assigned sources), which is what makes most sense in this scenario, then no buses or summing is required and it is an extremely simple and quick calculation for any processor/controller to do. I don’t see how that could ever be considered ‘wrong in regard to the real level’.
    I’m sure they already have a max function or similar coded into their metering that they use to determine peak for the existing multipoint metering that they could reuse.
    #96153
    SteffenR
    for me it would be enough to have a signal present and an over indication that’s it
    so if it’s doable, why not…
    #96154
    jb07
    I watched a video on the midas m32, and I was surprised to see some vu-meters on the DCA. I put my DCA on the custom layer and suddenly I no longer have a vu-meter.
    #96160
    SteffenR
    the Midas has no VU meter… just a PPM with the loudest signal
    https://en.wikipedia.org/wiki/VU_meter
    mostly we use PPM meters nowadays
    https://en.wikipedia.org/wiki/Peak_programme_meter
    #96161
    Profile photo of volounteer
    volounteer
    @SteffenR
    Only if ‘we’ means parts of EU.
    Many places still use VU meters.
    Others use variations on PPM-VU type measurements.
    PPMs were considered for use in the US, but rejected in favour of a ‘Standard Volume Indicator’ (VU meter) on grounds of cost. Joint research by CBS, NBC and Bell Labs found that using an experimental design of PPM (with a relatively long integration time of 25 ms) in the control of programme levels gave only a 1 dB advantage over the VU meter, in terms of average output level for a given amount of distortion. It was felt that this was too small to justify the much greater expense. It was also found that VU meters gave more consistent readings than PPMs
    #96172
    SteffenR
    since the extended use of analog to digital conversation it is more common to use PPM
    since these will detect overs much better than VU meters
    nearly all modern digital consoles have multi function metering instruments available with the ability to configure the characteristics
    but none of them uses VU characteristics as default
    #96176
    jb07
    What bothers me is having a fader mounted and no signal present indicated.
    Knowing that the level of an indicator will never be precise!
    #96177
    SteffenR
    jb,
    did you understand that the DCA carries no signal?
    so normally there is no real signal to display
    but I’m with you that there should be a signal present indication and an over indication
    maybe @keithjah can chime in and give us a hint how A&H will deal with this in the future
    #97175
    Profile photo of nottooloud
    nottooloud
    Say my DCA controls 3 channels and a group. Each of those channels is also in other groups. The group levels are all different. What would you put on this meter? You already have hidden layer clipping indicators.
    #97214
    SteffenR
    that’s the reason for my vote for a signal present and an over indication only
    this would not show wrong values…
