Using 7 stereo Mix on QU24
Forums Forums Qu Forums Qu general discussions Using 7 stereo Mix on QU24
This topic contains 19 replies, has 6 voices, and was last updated by Profile photo of debzdoodle debzdoodle 5 months, 3 weeks ago.
  • #97522
    Profile photo of john
    john
    So i have the qu-pac. And i think switching a group to mix mode isn’t going to work unless there’s a way to route it to mix out 1&2 since the wu-pac doesn’t have group or matrix iuts kn the back. Any help on routing to mix outs 1&2 would be appreciated! Thanks.
    #97523
    Profile photo of Mike C
    Mike C
    You can use the ALT OUT for an additional output if it’s not already in use.
    You can select the routing in the IO routing menu under the surface menu.
    Do you have a stage box?
    #97611
    debzdoodle
    Darn, I assumed you were using a D snake for the extra mixes – however as Mike C said, without a D snake you can at least get one more stereo aux by using the Alt out. I’ve done that too….
    #97613
    Mike C
    There’s been a couple times where I’ve used a stage box with my Qu Pac just for the additional outputs.
    #97715
    debzdoodle
    Yeah, I do it all the time. I couldn’t get by without a D snake these days….
