Forums › Forums › dLive Forums › dLive General Discussions › Synchronising Dlive, Macbook with Reaper & utrack24
This topic contains 21 replies, has 6 voices, and was last updated by wugang 3 years, 6 months ago.
2020/05/08 at 2:54 pm #91677
your problem will be a different one…
Reaper and Liveprofessor will not work with low latency at the same time…
Dante will not work with low latency at all in this setup
to use this for Playback would be no problem but it will not work for insert processing
so it would be better to cancel this
but reverbs could be doable…Can your U-Track send MIDI Time Code?
if yes then you can synchronize u-Track and Reaperif not there is another possibility
you can record timecode into your U-Track session as audio data on one track (make shure it is not clipping anywhere)
and play it back into your dLive and route it to a Reaper input with a Tie Line
the Tie Line will add around 0,7ms of latency
Reaper can sync automatically to that time code
I’m not shure but in this case it should start automatically when TC(from the u-Track) is started
the time to lock on the TC from the u-Track could be a problem, you just have to test it2020/05/08 at 4:48 pm #91684@steffen R, it would be very logical for the dLive to work with the MTC, but not 🤷🏼♂️
2020/05/08 at 8:42 pm #91692Thanks Steffen 🙂 That cleared my mind a bit.
Timecode is not a problem as we use it for the lighting guy and it’s already implemented in Utrack track nr 8 and i’ve already thought about it as a synchronising method.. I am not sure about what utrack can do with Midi unfortunatelly.
I will have to make deeper search about that. If I use utrack only tu start the session in the reaper that should do the trick and then You are right – I don’t need bome box.
Geting back to the live professor and Dante.
if I setup Live professor on another computer will I be able to make latency enough to insert plugins (at least some of them) via Dante card?? or i will be able only to use it for reverbs and Delays?? ( which in my case are 90% what i need )??
Will I be able also to record multitrack simultaneously on another computer via dante?? Or it’s just a russion rulette?? 🙂
2020/05/09 at 1:17 am #91705Reverb and Delay is save to work in Live Professor
insert processing depends on what latency is tolerable at your taskDVS has a given latency and LP adds a bit as well (and the plugins of course)
I guess it will be more than 10ms
the smalles value I tried was 15ms
and I ended up with about 20ms for save use with reverbsit is possible to get lower latency with dedicated DANTE Hardware like the Yamaha or Focusrite PCIe Cards or the RME Digiface DANTE
these do not use the DVS, they use dedicated ASIO or Core Audio drivers to realise lowest latency possibleone of the main problems you will have is the loose of the phase coherency of the complete mix since every plugin chain adds latency
so you need to process all channels or add a delay to the channels not processed with plug ins
and this can be a real challenge in a live environmentsince most of us agree,
that the internal processing with dynamics and equalisation is very good
and the most needed improvement is better reverb
above problems are not that relevant to the average userrecording and live propfessor at the same time should be no problem if you split it from the playback and not using to much processing in LP
or too many tracks to record2020/05/09 at 9:00 am #91710Hey 🙂
Steffent thank You for this huge explanation. Yes definetly the biggest issue is reverbs, and delays in Dlive. Well Issue is a hard word, but for what this console is it could have better FXes ( that remind me about digicos FXes).
External PCIe Dante cards with box to run it is unfortunatelly out of my budget. But I will check. Still I though that Dlive architecture will compensate to everything that would be inserted on the channels even if this is external processing via Digital link of course. i guss I misread it 🙂
thank You all for help. As soon As the Covid ends and I start to work again i will try tu bilt this connection and will let You know how it goes 🙂
2020/10/03 at 4:43 pm #95423Can you teach me how to use Reaper to send tcp/ip to change the dlive scene?
2020/10/05 at 7:58 am #95476use DAW Control
