Forums › Forums › SQ Forums › SQ general discussions › SQ to QU connections
This topic contains 53 replies, has 23 voices, and was last updated by nottooloud 11 months ago.
2019/03/18 at 8:33 pm #82799
Hi all,
is it possible to connect two QUs to one SQ, one via the SQs builtin port and the other one via a SQ SLink card?
2019/03/19 at 8:26 am #82812A QU can only be a master, as far as clocks are concerned. So just one can be in any setup.
2019/03/19 at 8:28 am #82813Hi @beppo ,
This is a good question, as all possible SLink connections from the SLink connections document can be applied to either the built-in port or the port on the SLink option card.
However…
The Qu cannot clock to an external source, so when connecting SQ <-> Qu, you must use the Qu as a master clock (set the SQ to clock from SLink).
If you had two Qu’s connected in one system as you suggest here, there would be two master clocks and you would only be able to clock the SQ to one of them.So unfortunately the answer is no – although this would seem to work, and give you some audio, one of the connections would not be sync’d and almost certainly give clocking errors resulting in audio pops and clicks.
Thanks,
Keith.2019/03/19 at 8:47 pm #82832Hi @keithjah,
thanks for the information. I had a SQ6 here for testing this weekend and i love this piece of gear. I’m thinking about purchasing a SQ5, but connecting a whole lot of synths and FX-pedals with mostly unbalanced TS-outs (and ins) to the SQs XLR inputs is realy a pita.
Using two Qu-SBs connected to the SQ would have been an alternative, although only working with 48 kHz. Too bad it doesn’t work.
2019/03/20 at 11:42 am #82841You know that you can use the AB168, AR2412, AR84 as well as the DX168 with the SQ desks if you just want inputs & outputs? If a second desk is really needed, one Qu-SB can be used.
If the problem is TS > XLR conversion, then there’s plenty of rack mount 8 way DI boxes you could get for much less money than a Qu-SB
2019/03/20 at 6:12 pm #82845Hello @markpaman, yes i know. But as i said, i have got many synths and FX units and i want to simplify my current mixing situation (6 mixers in total) and have more flexibillty in routing etc. And summing up the costs for a SQ5 + 2 x DX168 + DI boxes for 40+ channels + cables and the fact that cabling would not be less complex…
That’s why i’m looking for alternatives.
2021/10/03 at 11:21 pm #103795Hi all.
Just curious if using a Qu mixer for monitors and an SQ mixer for FOH, while also using a stage box as inputs, still requires two CAT cables and the additional S-Link port on the SQ at FOH? I’m assuming any firmware update hasn’t changed that, but thought I’d ask.
Does anyone know of a diagram showing this setup?
I’ve been a fan of A&H mixers since my first GL-2, many, MANY years ago. After several years on a GL-2200-24, I went digital with a QU-32. A few years later I added a QU-SB(and then an AR84 for another 8 channels) for smaller, more space constrained venues. Just bought an SQ-5 and a GX4816 stage box. Now that my show schedule is slowing a bit, I want to spend some time learning the SQ-5 and figuring out how to set it up with one of my QUs as monitor mixer, when I need such a setup.
Thanks for all the great info here.
2023/05/30 at 12:48 am #113091I have an SQ5 and an Qu16. I want to (as Keith outlined as a possibility) use the SQ as the venue’s main desk and the QU for a streaming mix.
I want the new tech running the stream, using the Qu16, to have a mix (locked custom layer would be nice) that he can adjust to taste. How would I patch this on our new SQ5? Do I have to make any I/O changes on the Qu16?
Thanks.
PS I’ve watched Keith’s brief video and I have a copy of this page:
https://support.allen-heath.com/hc/en-gb/articles/4403618840849-General-How-to-connect-Qu-SQ2023/05/30 at 1:16 am #113093SQ clock has to slave to the Qu, via SQLink. You can use the preamps on either one, although I would assume you want to use the SQ. Use tie lines to pass the inputs to the other board.
