So many really good and useful suggestions so far
Forums Forums Qu Forums Qu feature suggestions So many really good and useful suggestions so far
Viewing 7 posts - 31 through 37 (of 37 total)
  • #43512
    Profile photo of Anonymous
    Inactive
    I think that Mark was right and the SiEx doesn’t have that either. At least the manual 1.0 implies that, I haven’t downloaded v2.0 yet.
    #43513
    Profile photo of mervakamervaka
    When would you ever run aux fed subs pre fade? Lets say LR bus feeds mains, Mix1 feeds subs, and kick on CH1. All channels feeding Mix1 are post fade.
    The main CH1 channel fader would increase/decrease overall volume of the kick, and the CH1/Mix1 crosspoint would then become your blend, where 0dB would send an equal level of signal to mains and subs, and the +10dB headroom allows you to feed more to the subs than mains.
    The only use case i can think of for pre fade aux fed subs would be when you want to send significantly more signal to subs than mains, or to subs only, which would suggest your gain structure is wrong coming out the desk. I don’t understand when you would ever want independent control of sends to mains/subs?
    #43514
    Profile photo of Dick ReesDick Rees
    Hero…
    Are you using the Qu from stage currently? If so, what did you use previously?
    Just trying to get more of an idea where you’re coming from.
    Mervaka…
    I have the same question regarding pre-fader sends to aux-fed subs.
    #43530
    Profile photo of MarkPAmanMarkPAman
    “When would you ever run aux fed subs pre fade?”
    In a theatre environment for an effect, possibly? But in general no, not in music.
    #43533
    You do realize that with aux-fed subs run as you describe that the acoustic crossover point between your subs and tops is not stable but shifts in apparent frequency. The phase relationship also skews along with the shift.
    So your system response within the room will change right along with any changes you’re making with your designated channel/mix feeds. It will produce audible effects. Whether or not it will effect the listening experience depends on the room, but you won’t be able to hear it from your on-stage mix position.
    I’d want to hear any such phenomenon while mixing so it wouldn’t get out of hand.
    #46273
    Inactive
    As of firmware 1.7: nothing there.
    Time for me to get a real mixer and stop waiting and hoping in vain.
    #46277
    Inactive
    There’s quite alot in 1.7 – but since you’ve thrown your toys out of the pram you’ll never read this…
    In fact I don’t even know which feature you’re complaining about in this thread – you started off with 20+
