Forums › Forums › Qu Forums › Qu troubleshooting › Qu-Drive Compatibility Thread
This topic contains 60 replies, has 23 voices, and was last updated by David Haughton 6 years, 7 months ago.
2015/03/01 at 8:35 pm #45661
I’m using this one: Left Angled USB Extension
(Also from Amazon in Germany, if available again)
Be careful with the angle, for the Qu you’ll need a left angle one, and even the pictures of those Amazon links seem to differ, they don’t. The photographed sides of the connector differ!2015/03/09 at 11:36 pm #45861to answer my own question about my QU-16 working with my DAW Personus studio one pro yes it works perfect. im not to happy with the midi control its really glitchish real sluggish but I don’t need it anyway I just thought it would be cool to control the faders by the QU . im not lazy and it don’t really matter to me besides I am stoked that I can actually record the fx settings when im recording . my SL 16.0.2 wouldn’t do anything like that I would have to add the FX in the DAW . I really didn’t like the FX in the DAW .
2015/03/31 at 2:06 pm #46450Any new drives to add anyone, especially low profile/compact ones?
🙂BTW…. Is there any real benefit to using a USB3.0 extension cable when the QU interface is USB2.0?
2015/03/31 at 2:40 pm #46451Still searching for working low profile sticks myself, still no luck…
USB 3.0 cables at least have to follow tighter specs (to support higher speed). But for that small distance its probably academic only…
…and mine is blue… 😉2015/04/01 at 4:11 pm #46494I’ve had the same issue with the QU’s USB-B port connecting to the ASIO Driver under Win 8.1. Had to reboot the Qu before it would show up in the driver. I figured it would be more typical to have the QU powered up BEFORE the PC loads the driver to get it recognized.
2015/04/01 at 4:57 pm #46497Did an unplug/plug not reset it?
2015/04/16 at 6:25 pm #47048Thank you Nicola… 😉
2015/04/18 at 3:02 am #47089Since we now have this thread sticky, I’ll try to summarize which USB Flash Drives are approved to work with Multitrack recording (not covering HDDs here):
SanDisk Extreme 64GB
SanDisk Cruzer Fit 32
Lexar S33 64GB
Transcend JetFlash 710S 32GB
Kingston Digital HyperX (DTHX30) USB3.0 Data Traveler 64GB
PNY Turbo 64GbNot working up to V1.7 along several others:
SanDisk UltraFitFor general information on QuDrive and which other drives may be used for pure data transfer check out the official Understanding QuDrive page.
And here are some links to other threads related to QuDrive started resp. updated since this one:
Qu24 QDrive – No USB drive detected
qu drive
Flash Drive not on approved list.
which hard drive for multi track??
USB drive – Qu16
Error message but recording OK…and I’ve handed over a SanDisk Ultra and UltraFit to Nicola (what a pleasure to meet you!) in Frankfurt, crossing fingers… 😉
2015/04/22 at 1:00 pm #47267Just thought I’d let you know that we’ve updated the KB article today and added a few more tested devices.
2015/04/22 at 3:23 pm #47274Probably not online yet, still dated 11 July 2013, not mentioning the UltraFit in either category…
2015/04/25 at 9:00 am #47436SanDisk Cruzer Force 64 GB also works fine:
Using SanDisk Ultra Fit USB 3.0 Flash Drive 64 GB as Qu-Drive?
2015/05/14 at 12:05 pm #47983https://allen-heath.helpserve.com/Knowledgebase/Article/View/774/268/qu-drive–understanding-qu-drive-and-usb
We’ve just added a couple of USB sticks that have been tested for multitrack recording and playback, one of these is the ultra compact and inexpensive Transcend JetFlash 710S 32GB.2015/05/14 at 1:08 pm #47986Almost as if you’ve been listening 🙂
2015/05/18 at 7:45 am #48091I have a Seagate USB 3.0 for my 16, and a LaCie 2.0 on my 24. Both have worked without glitches, but check out my inquiry on recording levels…
2015/05/22 at 7:35 am #48198I have been using this USB . . . . described as tested for multitrack recording, and it doesnt work!
I managed to record a full hour start to finish so I thought Id got one to work. But since the first success, it now stops recording, QU stops recognising it, and requires the previously mentioned power on/off cycle to get the QU drive to recognise the drive again.
I have also tried 2 other tested and recommended drives (which I purchased for this purpose only!), 1 of them didnt work at all, and 1 worked once, then never again. I have tried reformatting these drives, still nothing. Seems they work once, and never again!
Am I missing something here? If these drives are tested, then surely, it should just work?
The multi track straight to disk is why I chose the QU16 over other competing desks in the price range and below
Any help would be appreciated
The topic ‘Qu-Drive Compatibility Thread’ is closed to new replies.
