Forums › Forums › Qu Forums › Qu general discussions › QU24 need an Amp
This topic contains 16 replies, has 7 voices, and was last updated by Ash 9 years, 6 months ago.
2014/09/12 at 2:32 pm #41577
Hi I’m a newbie and this might be a silly question but can anyone suggest some pa amplifiers to go with QU24…..I got the mixer now need an amp……currently got speakers at 8ohms at 350watt each
Regards
Ash2014/09/12 at 2:48 pm #41579Lots of good amps. QSC is my preferred. Crown, Lab Gruppin and others.
2014/09/13 at 12:40 am #41588Usually the amplifiers are chosen to suit the speakers and your requirements, not the mixer.
2014/09/13 at 11:27 am #41589Like George said QSC good value and reliable.
GX5 sounds about right for your speakers, built in x-over if you need it too.
Nice little amps:)2014/09/13 at 12:03 pm #41590Thanks wonder if anyone has an opinion on Yamaha P7000s, someone recommended it to me….
2014/09/13 at 12:32 pm #41591Yamaha used to build pretty decent amps. Some were very revered. I have not used any in a long time I am sure they are probably fine. As previous poster said you need to consider what speakers are going to be on them and the general usage as to levels etc. It is more about that than what mixer they are hooked to.
I have always told people. Speakers and power are the big concern. Give me plenty of power and great speakers and I can put a $100 mixer on it and sound great. Give me the opposite, crappy speakers and low power and I don’t care if you put a $100,000 console on it, it will sound like crap.
2014/09/14 at 10:36 am #41611
AnonymousI know that its a bit off topic for this forum, but I was wondering if you have had any problems with noisy fans in QSC amps. My church as a QSC GX5 amp for FOH in the rack under the mixing desk. The noise of the fan always drives my crazy especially when its quiet in the room. Fortunately you can only hear it whilst in the mix position.
2014/09/14 at 11:49 am #41614Hey Brendon,
I haven’t noticed them being especially noisy, I’ve owned 5 of them, still have 3.
You can hear a whir for sure, but nothing particularly distracting.
Then again, I’m not using them in dead quiet rooms most of the time.2014/09/14 at 2:04 pm #41616I have several 3’s and 5’s out on church installs. I don’t recall any being overly noisy. I have a few in situations where if they were it would be a problem. I would suggest you checking into whether yours has a fan problem.
2014/09/15 at 6:34 am #41657I’ll plus one on qsc’s
Best bang for the buck…
I’ve switched to powered cabinets for almost everything…Usually the K-series…Although I don’t like thier crossovers…I run the EV DC-ONE for mains distribution/eq/delay/crossover/etc…
2014/09/15 at 7:26 am #41661
AnonymousThanks, I’ll look into it a bit more and press my supplier for a response.
Performance certainly seems normal, there’s no issues with air movement, cooling etc.
It’s just very much noticeable compared to the old FOH amp (which now lives in the rack serving as foldback amp) and most other brands that I’ve used.One thing that did trouble me with it a touch when I first pulled it out of the box was the remarkable resemblance in appearance to one of Behringer’s amps. Hopefully the similarities start and stop with the outer case…
2014/09/15 at 9:17 am #41668Don’t panic Brendon – they’re not anything like a B*******r!
BTW, typical B*******r to copy the look of something good.2014/09/17 at 1:56 am #41697I purchased four QSC PLD 4.5 amplifiers about 9 months ago
and they are completely awesome, amperage draw is incredibly low and excellent built in processing.I used to be a Crown guy…
Service by the QSC company is second to none.2014/09/17 at 2:42 am #41699Just installed 2 PLD 4.3 driving QSC ILA 6 box line array. They are really cool amps. Not your grandpas power amp. Bit of a learning curve. A&H GLD 112 AR2412 and 084 on the front end.
2014/09/18 at 6:26 pm #41721GCumbee,
I really like them too! -
