Thanks for that info NZdave.
I see that you are using Reaper. I have two questions for you about Reaper if you don’t mind:
My scenario: I have the new QU-24, but I am currently running Presonus Studio One Pro3 as my DAW on my Desktop PC. I knew I couldn’t use the PC and had to change to a Mac before I purchased the QU-24. I am intending to buy an iMac 27″ in the near future. What I didn’t realize was that Presonus Studio One Pro3 wouldn’t work with the QU-24, because it does not use the HUI or Mackie protocol. It has it’s own proprietary protocol. I’m bummed about that because I really like Studio One. So, now I have to purchase a different DAW. I saw that A&H lists Reaper as one of the compatible DAW’s. My main question is around automation. Can the QU-24 perform mix-down volume automation with Reaper, where I can go back and make additional changes after the initial mix-down and then do it again as many time as I need to? I hope I explained that question correctly. And in general how do you like Reaper?
Thanks again.
Cheers,
Salislore
