Forums › Forums › Qu Forums › Qu general discussions › Qu-32 for a Home Studio set up?
This topic contains 18 replies, has 7 voices, and was last updated by Anonymous 3 years, 7 months ago.
2020/09/03 at 10:37 am #94577
AnonymousHi there, I’m looking for people’s experience of using the Qu-32 in a home studio set up. I’m currently using a Presonus 16.0.2 Studiolive desk which I’ve been pretty happy with but, as my set up has grown, I really need more inputs. I mainly work with hardware synths/sequencers but use Ableton for arranging/mixing etc. I realise the Qu range is primarily aimed at live use but the 32 is the only desk (AFAIK) within my budget with that amount of inputs so seems to fit the bill. One thing that puts me off is that I like to be able to process signals through external hardware (filters/fx etc) but I guess I can use the Mix outputs as Aux sends & return via an input.
Any views/advice would be highly appreciated – thanks in anticipation.
Andy
2020/09/03 at 11:07 am #94583yes it’s possible
and your question is not very specific
consider the SQ series
the audio quality and flexibility is much better as on the QU series
and it’s easy to add input sockets with expanders if your needs grow
internal processing is 48 channels and 4 fully usable send effects
and it supports real hardware insert processing what the QU series does not2020/09/03 at 12:43 pm #94588
AnonymousThank you for your reply Steffen. I rarely need to use mic inputs, purely line inputs so it looked like the Qu-32 would be a more direct upgrade from my current set up in that it instantly more than doubles the inputs I have with the Presonus & with better internal FX. Whilst I can see that the SQ series is a further significant upgrade, it is also out of my budget. Any further thoughts welcomed. Best wishes.
Andy2020/09/03 at 1:54 pm #94590Also be aware the QU board’s use only 48khz sample rate (adequate for live). The SQ’s use 96.
2020/09/03 at 2:18 pm #94594the SQ-5 is cheaper than the QU32
2020/09/03 at 3:25 pm #94604
AnonymousThanks Steffen, but the SQ5 only has 16 mic rather than line inputs so doesn’t really get me any further than my current set up (other than the higher sample rate).
2020/09/03 at 4:01 pm #94609@AndyRoger
If you want outboard fx then consider a used analog mixer.
Personally I would go all digital as it is much better cheaper easier to use.
OTOH I would find the Qu32 overkill for home as I can mix stems, from those sources you note , in the DAW without needing 32 outboard channels.2020/09/03 at 4:57 pm #94611Thanks Steffen, but the SQ5 only has 16 mic rather than line inputs so doesn’t really get me any further than my current set up (other than the higher sample rate).
That’s not completely true. The SQ5 have 17 MIC Inputs and three Stereo inputs which also can be used as 6 Mono inputs (ok, ST3 in is a little tricky). So you have at least 23 Inputs on that Console from the scratch. And you can extend it by using digital Stageboxes. And furthermore it is more flexible in case of routing. E.g. you can use the USB-Interface to connect the computer and use the hardware sockets to realize inserts for your channels. Something you can’t do on the QU series.
2020/09/03 at 5:12 pm #94613SQ-5 has 17 XLR inputs, 4 jack inputs for line level and a mini jack for stereo line in
all in all 23 analog inputs on the desk itself
all patchable to any wanted channel
you can combine two channels to a stereo channel (one fader but L/R signals)you have several layers to arrange your strips freely
it’s so damn flexible… choose the SQ-6 and you have 8 XLR sockets more and it’s a bit over the QU-32 price
2020/09/03 at 9:57 pm #94618
AnonymousOk, thanks to everyone for their input – food for thought…
2020/09/03 at 10:27 pm #94619
Anonymous@steffenR
Really? I didnt think any of the digital Allen Heath desks do that to keep all data totally phase?
Even now I still have a QU32 AND I use a QU16 simultaneously for surface area into my Imac.
And I know that eventually the way to go is 96K
However just think of… gosh it must be 30-40 years of recordings at 44K and Adats at 48KYes all good food for thought
2020/09/04 at 4:52 am #94625I didnt think any of the digital Allen Heath desks do that to keep all data totally phase?
Nobody said that the signals will be in phase.
This is from the current reference manual:The insert points on SQ can be used to route audio to and from any available I/O sockets, allowing analogue or digital processing to be inserted into the channel.
Inserts can also be used with the internal FX engines. See the FX engines section for more details.But it is quite sure that using some effects on the channel insert, regardless whether it is an internal FX from the FX rack or an external effect, will add some extra latency.
2020/09/04 at 11:03 am #94632Really? I didnt think any of the digital Allen Heath desks do that to keep all data totally phase?
On the top range consoles it is(was) a selling argument to be able to insert analog voice processing into the channel strip
or do some magic bus compression with real analog hardware, and even on the SQ you can use some Waves sound grid processing in inserts.But this is not possible on the QU series, related to the architecture.
2020/09/04 at 8:03 pm #94645
AnonymousOK…. So its not a TRS insert as such like analogue consoles as such?
One would have to use Aux sends and then return those through strips or ST1/2 in?I did have a look at an image of thre rear of the SQ yesterday and couldnt see any Insert plugs?
Cheers guys thanks.2020/09/05 at 12:09 am #94647@xyz
yes
you have to send it out somewhere process and then send it back in another input
there is no y cable type insert ability like analog had
so far fewer inserts possible than an analog mixer with one insert on every channel input
