QU-16 with AR2412
Forums Forums Qu Forums Qu general discussions QU-16 with AR2412
This topic contains 16 replies, has 6 voices, and was last updated by Profile photo of cornelius78 cornelius78 7 years, 5 months ago.
Viewing 2 posts - 16 through 17 (of 17 total)
  • #40182
    Profile photo of Ton
    Ton
    How long can i run the single balanced XLR cable? Could it be the same length as the CAT5 cable which may go upto 100 meter?
    #40185
    cornelius78
    Depends on the cable. If it’s a proper AES/EBU cable (110 Ohm impedance,) you should be fine for several hundred feet. If it’s a generic mic cable (with a different impedance than what the AES sockets are expecting,) they tend to be fairly hit and miss, and people tend to not be able to get more than a few meters out of them, (something to do with the different impedance causing the signal to be reflected back inside the cable, resulting jitter/clocking issues, and ultimately errors that result in loss of sync.)
