Pre-Mute Aux Send
Forums Forums dLive Forums dLive General Discussions Pre-Mute Aux Send
This topic contains 15 replies, has 5 voices, and was last updated by Profile photo of  Anonymous 4 years, 6 months ago.
  • #85780
    Profile photo of
    Anonymous
    Is it possible to create a Pre-Mute Aux Send for a mix that stays active even when a channel is muted?
    #85788
    Profile photo of SteffenR
    SteffenR
    not in this system…
    in Allen & Heath world a mute mutes everything
    Why do you need this?
    #85790
    Profile photo of
    Anonymous
    Same in Yamaha world, unfortunately!
    It’s for a backline mix so he can hear instruments before they’re unmuted for checking and tuning.
    #85792
    Profile photo of Runepune
    Runepune
    Create a digital split and gang the channels? Except mute and sends, obviously 🙂
    #85849
    Profile photo of Michael
    Michael
    Depending on your global settings for direct outs, you could also use a pre-mute direct out.
    #85852
    SteffenR
    How about a second PAFL?
    #85866
    Profile photo of
    Anonymous
    Can each PAFL have separate settings? IE mix cue vs last cue?
    #85877
    SteffenR
    since 1.80 you can send a mix (IEM) to a PAFL bus and can configure them independent from each other,
    separated PAFL settings
    #85887
    Profile photo of
    Anonymous
    Very cool.
    Now if only they would add PAFL buttons to OneMix as I’ve been whining…
    #85895
    SteffenR
    that would be silly… it will become a two mix app
    one aux and one PAFL
    #86902
    Profile photo of Senny
    Senny
    With custom control you don’t really need onemix, just a bit of time with setting up layouts.
    But they demonstrated this in their webinar, which I thought is a very ingenious implementation.
    #86920
    Profile photo of
    Anonymous
    Incorrect.
    Tons of reasons to have PFL for a musician, director or tech using OneMix. Tuning his instrument while in a scene where the channel is off, for backline techs who need to hear different instruments throughout the show, for people practicing without disturbing others (if their channels are off on the console), musical directors wanting to solo up specific instruments to hear how people are doing, people soloing a mic they don’t have in their mix (like a talkback or audience mic) – there’s lots of reasons!
    #86932
    SteffenR
    All this is in my opinion not a usecase for OneMix
    OneMix is the simple and easy to operate monitor mix solution.
    You can build your own system with Custom Control for your needs…
    #86948
    Profile photo of
    Anonymous
    Certainly that’s one way, but in it’s current form, it’s got a lot of limitations. No eq or processing adjustments, for example.
    Just add a PAFL button on OneMix. Simple. Done.
    If you don’t like it, don’t use it.
    #86949
    SteffenR
    why is it that hard to understand?
    that is not simple… wich PAFL for wich OneMix?
    and you need more buses per monitor mix
    this would be a real challenge and the effort is to high for that limited use
    OneMix is a easy to use personal monitor control app and that is ok.
    I don’t want to say the idea is bad,
    I’m just trying to explain that changing OneMix is not the solution for your particular problem
