Noisy fan on CQ-18T
Forums Forums CQ Forums CQ troubleshooting Noisy fan on CQ-18T
This topic contains 22 replies, has 14 voices, and was last updated by Profile photo of Chienmort Chienmort 1 month, 1 week ago.
Viewing 8 posts - 16 through 23 (of 23 total)
  • #119319
    Profile photo of willmodelisme
    willmodelisme
    Fan speed idle on my CQ12T around 1000 rpm, just for info.
    #119324
    Profile photo of SPS
    SPS
    òWillmodelism: Thank you for the information! i suppose there is a problem with the awm control of my unit… hopewell…i’ll let you know
    #120792
    SPS
    Got back my mixer from assistance after more than a month: found pinched a cable of the fan and changed all the electronic board (?). At last now running @450rpm and really almost unudible.
    #120793
    Profile photo of Z O L T N
    Z O L T N
    I would hope this merits a recall. Or does each customer have to open a support ticket to get this issue fixed?
    #120816
    SPS
    If i was you, would seriously consider to call A&H local support and solve the problem: donnow if your noise is louder than mine before being fixed, but consider that actually in my room (very quite and with only the mixer powered on) at the distance of 1m i can hardly hear the slight blowing of the fan.
    #120817
    Profile photo of Brian
    Brian
    Just received my Cq-20b and have to add to this list, fan noise, while not loud, is rather annoying. It’s winter here in Boston and my studio is cool, shouldn’t even need a fan.
    The device is generating it’s own heat. Therefore while the ambient temperatures can plan a small role in heat mitigation, it doesn’t change the fact that the chips are generating heat that needs to be mitigated/managed. In other words, just because your studio is only 60 deg Fahrenheit doesn’t change the fact that the chip might be outputting heat measured at 200+ deg Fahrenheit which needs to be managed properly.
    #120954
    Profile photo of millerthriller
    millerthriller
    Here as a comparison the Info from my CQ20B. Environment is at 20°C. Device ruining ideale for about 15 Minutes
    Allen & Heath CQ Mixpad V1.1.3 – Rev. 80777 1.1.3.80777
    Unit Type: CQ-20B
    DDR Calibration: RU:0 RO:0 FF:0 FE:1 C1:1 C0:1 PASS
    Core Temp: 75.79C (Max: 76.29C, Min: 26.45C)
    Core Voltage: 0.998V (Max: 1.004V, Min: 0.996V)
    DAC Temp: 38.00C (Max: 39.00C, Min: 22.00C)
    FX Temp: 72.72C (Max: 73.33C, Min: 26.09C)
    Fan Speed: Fan 1: 1052rpm
    Fan PWM: Fan 1: 34
    TFT PWM: 90
    MAC Address 1: 00:04:c4:0f:37:e0
    MAC Address 2:
    Firmware Version: 1.1.1 r3684
    IP Address 1: 192.168.2.1
    Active Image: 0
    Bootloader Version: 2151
    FPGA: 1/12/22/ 10:35:23
    OS State: 1
    Audio Board: Type 2
    DNA Valid: true
    DNA: 100E-75CC-5C73-30
    Fan between 1050 and 1100 RPM and not loud at all….
    I guess my ambient temperature is by about 5°C lower (you can see it at the mininmum temparerture readings).
    I would expect that the fan is running faster if the ambient temperature is higher, but 2500 RPM at a slightly higher ambient temp. Doesn‘t sound logical.
    #120964
    Chienmort
    My CQ20 fan is quieter than ambient, so I suspect inside the level A&H quote. Of course I have no experience with the CQ18 .
    I have looked a fan noise reduction on amps before and there are two types of noise. The first turbulence, the noise generated by the rotation or the fan blades. It is hard to reduce this as it is proportional to fan speed. Slowing the fan speed will improve it BUT reduce cooling.
    The second is transmitted vibration, where the mechanical vibrations are conducted through the metalwork.
    Finally the fans could be out of spec noise wise. There is nothing that can be done on a forum to decide that so you will have to get back to the Distributor/AH.
