Forums › Forums › iLive Forums › iLive troubleshooting › New touchscreen SBC unable to connect to mix rack or surface
This topic contains 26 replies, has 10 voices, and was last updated by Anatolii1976 1 month ago.
2018/05/04 at 9:02 pm #70795
I have installed a new SBC for the touchscreen in a T112. It boots up fine but is unable to connect to the mix rack or surface. I’m assuming this is something to do with the network settings of the new SBC ‘if’ I were able to access the ubuntu command prompt does anyone know how I can configure it to ‘see’ the mix rack and surface?
2018/05/05 at 3:36 pm #70803As A&H no longer support the iLive does anyone know anyone with the capability to programme the touch screen SBC?
2018/05/05 at 5:47 pm #70806Alt+F1 should give you a CLI
eth0 should be set to 192.168.1.3make shure you’re using the right software version
2018/05/05 at 8:51 pm #70810I’ve managed to log in and get access to the command prompt but how to I tell it what address it should be on?
I tried adding the network information in etc/network/interfaces but this made not difference.
I added the ip, sub net and gateway but this made no difference
2018/05/06 at 9:51 am #70825what is your IP configuration now?
2018/05/06 at 8:50 pm #70848I edited nano etc/network/interfaces
Made it static and added
Address 192.168.1.3
Netmask 255.255.255.0
Gateway 192.168.1.254But this made no difference
When I went back to this file the whole page appeared to be empty and it said new file at the bottom.
I’m not in any way familiar with Ubuntu so I have no idea how to check if what I entered is now gone and I should enter it again.
2018/05/07 at 9:12 am #70857did you made yourself root?
start the command with sudo
otherwise you have no writing permission to /etc/network/interfacesI think the easy way is to write to A&H I guess they will help you with some more information
2018/05/07 at 9:23 am #70860Yes I am root.
The last time I contacted A&H support regarding the iLive SBC they told me to contact Audio-Technica…
2018/05/07 at 1:30 pm #70869Do these settings look correct
2018/05/07 at 1:33 pm #708702nd attempt and file size was too big
You must be logged in to view attached files.2018/05/07 at 1:40 pm #70872Does anyone have a list of things that need to be entered into ubuntu in order for it to see the mix rack and surface?
2018/05/07 at 2:56 pm #70875Ok, so it looks like I’ve fixed it! I was configuring eth0 (because that was what all the forums were telling me) but when I checked it, it was saying no such device and only eth2 and eth3 were showing up so I configured them and it worked! I’ve now got it connected!
2019/01/04 at 3:07 am #81230HI Dymondaudio, I have just taken my T80 apart and identified that the SBC is not booting up. just wondering, where did you get your new SBC? Any pointers would be greatly appreciated. My local dealer certainly doesn’t have it.
2019/01/04 at 11:45 am #81234Where are you located……
In the US, I dealt with this company:
American Music & Sound
support@americanmusicandsound.com
1-800-431-26092019/01/04 at 8:41 pm #81246It took me an age to track down a replacement as they are no longer stocked anywhere. I managed to find a second-hand one being sold by a company in Germany, I then had to programme it myself which was not the easiest thing in the world as I am not a software programmer however I managed to do it and it works perfectly to this day.
One thing to try is replacing the bios battery as these will stop it booting if it’s flat.
If you remove your SBC you’ll be able to find out the make and model, they are not all the same.
