Hi Djam,
What are you recording currently? Mutlitrack with direct outputs or Stereo with a mix bus?
If you are multitrack recording, I recommend using the direct outputs, as this means you can boost the level using the direct output trim.
If you are using the stereo recording, you could use an available mix bus to do a dedicated recording mix.
Thanks!
Alex
