itunes and mac
Forums Forums Qu Forums Qu general discussions itunes and mac
This topic contains 24 replies, has 7 voices, and was last updated by Profile photo of Nicola A&H Nicola A&H 9 years, 3 months ago.
Viewing 15 posts - 1 through 15 (of 25 total)
  • #39246
    Profile photo of mimmo
    mimmo
    Hi, a simple thing I hope.
    I connect my apple pc to UBS B of my QU-16; my pc recongnize qu-16, but I ’m not able to listen music from itunes (even if I choose right input channel 3° stereo input).
    thank for help. Mimmo
    #39253
    Profile photo of moon
    moon
    You have to go to the MAc Audio Midi setup application and specify
    QU-16 as the output for the MAC.
    cheers,
    Mike
    #39258
    mimmo
    Thank you so much mike. I have just done it.but i can listen test speaker configure. But not the iTunes music. I note that i’m not able to move the orizzontale bars that increase the tracks db….
    #39259
    Profile photo of
    Anonymous
    Apple Mac? PC? which one?
    If you can hear the test sound coming back into the ST3 channels (which should be turned to USB-B input) then it must be a problem in your mac
    dave NZ
    #39261
    mimmo
    it’s a mac. Yes, I can hear mac test sound on ST3. But i cannot open any of the 21 channel outs (master bar too). Mimmo
    #39268
    Nicola A&H
    Keymaster
    Check that audio from iTunes is not going to Channel 1 & 2 on the mixer. If it is, you have to patch the standard OS X stereo output to a different USB out. In Audio MIDI Setup, select the Qu audio device and click Configure Speakers, then assign the stereo output to 21-22 for ST3.
    Hope this helps.
    #39269
    mimmo
    Hi nicola (are you italian?).
    Itunes don’t have an option in which choose outputs (or pheraphs i’m not able to find it ?).
    Anyway I immagine you mean to patch it in “Audio MIDI configuration” of my Mac.
    Yes, I did this on my mac:
    1- I choose QU-16 usb in “Audio MIDI configuration”
    2- I choose in “configurazione spaeakers” stereo and I pacth the 21 for left and 22 for right (in this there are two audio test bottons for each speakers: if I push both of them they works well, and I can ear signal tests coming from mixer in right ways).
    But nothing happen if I play Itunes (or i.e. Youtube ecc ecc).
    (If could be usefull, in “Audio MIDI configuration” of my Mac it happen that I cannot move any of volume bars (output section)).
    I dont’ know if i have to do something else in my mixer, but i don’t think so if it well works with signal tests.
    #39275
    Profile photo of Tom
    Tom
    Mimmo,
    There is one more thing you need to check and/or set. Go to System Preferences > Sound and make sure that the output is set to the QU-16.
    I hope this helps!
    #39289
    mimmo
    ..hi Tom…thank you so much …but… just done!! …(i’m checking if could be some conflict with my old edirol audio system i had before installed… i don’t really know!!
    #39293
    mimmo
    A information on more…. i try to set usb B in CH1 and CH2 and they receive regolary music independently from what i do in midi audio set up. So it seem pc transmit only out in CH1 and CH2. …some suggestions?
    #39298
    mimmo
    A further information: nicola is right. i try to set usb B in CH1 and CH2 and they receive regolary music independently from what i do in midi audio set up. So it seem pc transmit only out in CH1 and CH2. …some suggestions to change these channel into 21 and 22??
    #39301
    Profile photo of
    Anonymous
    Hello Mimmo.
    Do these pics help you?
    #39306
    Profile photo of
    Anonymous
    and these pics?
    Good luck
    cheers
    dave NZ
    #39313
    mimmo
    Thsnk you so much for helping.
    I attach my pics too…..
    #39314
    mimmo
    Pic
