Forums › Forums › Qu Forums › Qu general discussions › Individual FX-send to fader?
This topic contains 19 replies, has 7 voices, and was last updated by Pidermite 3 years, 7 months ago.
2020/08/22 at 11:56 am #94289
Is it possible to assign individual send to faders?
What I want to do is to have two delays and two reverbs to lead vocals and chanege their levels very fast from a song part to another. And same time change dirty voc to clens. That’s impossible via menu-surfing. Do not want to do this via scenes etc as levels dirref very mauch according to space.
Done this with Yamaha (QL/CL) using 3rd party MIDI-controller, probably would work with A&H as well, but could be nice to have this feature inside the console.
2020/08/22 at 12:36 pm #94290wich Qu? what you mean with individual?
2020/08/22 at 12:53 pm #94292btw… no menu surfing involved… I don’t get it
maybe you should read the manual first
2020/08/22 at 12:56 pm #94293Did read the manual, did not find the answer. I want to have my four fx-sends (2 x dly, 2 x rev) of lead vox on surface all the time. Asked for SQ, but why not in other product lines as well 😉
2020/08/22 at 1:07 pm #94295wich QU?
QU-16 has only two dedicated FX sends
QU-SB and QU-PACK have no faders at alland no it’s not possible
I guess you play an instrument at the same time….on SQ you have the possibility to select a channel and then press “CH to All Mix” button and now you have all your mixes to that channel on the surface…
but you have to hold the button…for this mode… and this has reasons…
we don’t wont to change that behaviour just to fit your need and make the live for all others much harder2020/08/22 at 1:15 pm #94296I think I mentioned that I want to make adjustments in FX-sends AND channels at very same moment. Dirty voc down, clean voc up, short delay down, lond delay and reverb up…
I think it should not be a big issue (at least in programming point of view) to make individual sends possible to assign them to faders. As well as any parameter f ex to user knobs. Of course it’s possible that the basic arcitechture of the operating system limits this possibility.
And my question was: If this is possible? I assumed not as there was no mention in manual.
And I messed the product line, what i meant was SQ-series.
Cheers
2020/08/22 at 2:16 pm #94298You can assign the fx send/return faders to your custom layer, placing them right next to the vocal channel fader.
2020/08/22 at 3:04 pm #94300You can assign the fx send/return faders to your custom layer, placing them right next to the vocal channel fader.
thats not what he wants to do
2020/08/22 at 3:24 pm #94301You can assign the fx send/return faders to your custom layer, placing them right next to the vocal channel fader.
This is exactly, what I’ve done, but I do not want to adjust the fx send/ret masters, but the sends of (one) individual channel 😉
2020/08/22 at 4:25 pm #94303and still this is not possible
this would break up the conceps of the console itself… this will make the Mix buttons useless and would introduce uncommon behaviour
we already discussed this earlier this yearand there where suggestions from different users as work arounds
try to search…
2020/08/23 at 3:19 pm #94317Does the answer given in the SQ section by https://community.allen-heath.com/members/mfk0815/
Work for you?2020/08/23 at 7:07 pm #94321@Pidermite
WHICH QU are you using ?
The manual is difficult to find information in for sure.
Almost always the info is in there somewhere, but NOT all the time, and often when it is there it is hard to find as there is no index nor cross reference but merely a TOC which is far short of a true index for usefulness.Pls try to rephrase the question and be more specific and complete.
I do not see the problem you seem to have.
We use a Qu32 so again which Qu do you use and exactly what is your real problem.Or do you really have an SQ? Same question comes up in both forums.
There was an answer there although the link from above does not seem to go to the question or answer.2020/08/23 at 8:15 pm #94322It seems like he has an SQ.
I was certain I posted a response here how to do crude work around to do what he wants to
do on a QU mixer and how to use all four FX slots on a QU16.2020/08/23 at 8:59 pm #94323I saw some responses in the SQ discussion.
But Marks link went to Klaus’ info page not the message.2020/08/24 at 7:56 am #94331Not sure how I did that, sorry.
Try:
but if this is no better, it’s the 3rd post in the thread “Individual FX-send to fader?” -
