Director and MIDI
Forums Forums dLive Forums dLive General Discussions Director and MIDI
This topic contains 28 replies, has 6 voices, and was last updated by Profile photo of Eric LeClair Eric LeClair 5 years, 9 months ago.
Viewing 15 posts - 1 through 15 (of 29 total)
  • #72010
    Profile photo of Jens-Droessler
    Jens-Droessler
    Is there a way to use a (USB-)MIDI controller (with faders and rotaries) with Director? It would make setting up shows at the office PC much easier.
    #72021
    Profile photo of
    Anonymous
    Not sure if Director responds to (or sends) MIDI commands.
    #72031
    Not that I’m aware of. Director is all GUI. You could try using Osculator to map midi controller stuff to director shortcuts, but probably not faders/rotaries.
    …that is, assuming you’re working in offline mode?
    You can *totally* do this w/ osculator and director if you’re actively connected to the mixrack. (Or natively on the midi controller if the messages are customizable.)
    #72038
    Jens-Droessler
    Alright. So that means I have to get the mixrack into the office if I wanted to use a MIDI controller (I have some BCF2000 usually used for small lighting stuff, but be could used for that). That’s still better than hauling the surface in just to make pre-show setup easier. So how do I do it? BCF2000, Windows PC and mixrack… and now? I guess I need something to translate MIDI from the BCF on the PC to TCP-MIDI for the mixrack to understand?
    #72159
    Jens-Droessler
    So I found A&Hs TCP MIDI driver. It is currecntly not available for Windows. This “currently” seems to be the case since 2014. WTF, A&H??? So you leave it like that, knowing that Windows users can’t use MIDI on dLive? Is there any alternative driver?
    #72167
    Profile photo of Nicola A&H
    Nicola A&H
    Keymaster
    Jens, as I said in another thread, DAW Control V1.5 for Windows has a ‘thru’ mode which presents the dLive MIDI to a virtual MIDI port, essentially replicating the function of the TCP MIDI driver.
    #72180
    Jens, I haven’t tested the DAW control 1.5 thru on windows yet, but assuming it behaves the way TCP midi driver does on Mac, problem solved! The catch is, in order to use your BCF2000, you’ll need to translate the incoming midi hex to values the BCF2000 can use, and vice-versa for the backmapping path to dLive. (If I recall correctly BCF uses Midi CC?)
    Mostly I live in OSX environments, so I don’t have a ton of experience with this kind of build on windows, but I did a quick search, and it looks like Bome Midi translator will definitely do what you need:
    MIDI Translator Pro
    If you do try out the AH Daw control 1.5, I’m anxious to know if they allowed it to auto-connect on computer boot like the TCP midi driver does on OSX!
    #72181
    Profile photo of RS
    RS
    No, DAW control is not auto connecting on my win10 machine. I filed that to A&H support and got “I’m not clear on why DAW control loses connection, this may be a Windows thing rather than a DAW control thing. I will consult the R&D dept.” as a answer.
    As this post is from back in April, I will bump it….
    What are you using on Mac for translating MIDI CC?
    #72191
    Jens-Droessler
    Tried DAW control. Can connect to Director, but nothing else. No MIDI port is provided in the system and there is no option to select an existing MIDI port in the system. The one sentence in DAW control’s instructions on “MIDI thru” is very sparse.
    #72192
    Osculator:
    https://osculator.net
    It’s absolutely incredible. Virtually bulletproof, uses very little system resource, gives you all kinds of data manipulation capacities.
    I’m still working on a dLive midi message catalogue for it. I’ve got all of the main faders/mutes catalogued. I’ve used that data to link faders between two consoles (FOH/Broadcast,) to supplement embedded recall when I have to run both at the same time. Remote embedded recalls are great, but sometimes you really just want manual fader control.
    As of this moment I do also have every known desk message captured in an Osculator library. …but in the fun part of that: working on labelling every message/making sure values in hex are given float substitution values, for each message. I’m up to sends… +/- 24 sends per channel, 128 channels…
    I have a feeling I’ll be here a while.
    #72193
    Jens, Have you tried looking at what’s going on w/ a midi monitor running? I see that windows has a, “midi Mapper,” does that allow you to configure software as a “device,” in a Windows environment?
    You might also see if AH ever got Tobias’ rtpMidi working as an alternative.
    #72215
    Profile photo of
    Anonymous
    Just tried dLive Director 1.70 with DAW control on Windows 7. What do you know? Director DOES send MIDI messages.
    Fader, Mixes, etc. do send MIDI messages. Checked it using MIDI-OX.
    Just set the IP to the computer running Director and click “Connect”. The Virtual MIDI ports show up as “DAW MIDI Control 1” in MIDI-OX.
    Not sure if Director RESPONDS to MIDI messages, however.
    #72223
    Jens-Droessler
    The picture is the same as on my PC, however no virtual MIDI port shows up in the Windows system. Also, if there is no virtual MIDI In for DAW control on your system, there’d be no way to send data TO Director via DAW Control and I could stop my attempts right here, because that is the part I’m interested in.
    #72245
    Profile photo of
    Anonymous
    How do you know there’s no virtual MIDI port? It’s definitely there on my system.
    But, you may be right. I cannot get Director to respond to any MIDI messages.
    #72258
    Profile photo of RS
    RS
    Just got a reply email from support concerning auto re-connect of DAW Control:
    “I’ve spoken to the development team about this again, we’re going to look to add auto-re-connection to DAW control in the future for you.”
