DCA affecting monitors
Forums Forums dLive Forums dLive General Discussions DCA affecting monitors
Viewing 15 posts - 16 through 30 (of 30 total)
  • #61894
    Profile photo of tpauldingtpaulding
    Nicola you definitely understand my position. Thanks.
    #61897
    Profile photo of Anonymous
    Inactive
    That makes more sense. A lot of confusion in this thread.
    However, Muting a channel by activating a DCA mute is very non-standard. A DCA as I said is a remote control for the channel faders, basically, so muting a DCA should be equivalent to pulling those assigned faders all the way down, not turning the channel off.
    Sent from my iPhone using Tapatalk Pro
    #61901
    Profile photo of ddff_lvddff_lv
    I can think very few uses of DCA mute not muting prefade auxes. In most situations that is a nightmare.
    ddff
    #61902
    Inactive
    ddff
    That’s what mute groups are for, not DCA mutes.
    #61904
    Profile photo of boluponabolupona
    I stand corrected!
    #61912
    I think most of us come from analog world- haven’t seen a desk where VCA mute would not mute assigned channels. It is not that difficult to pull fader down if you need pre-fade auxes to work.
    ddff
    #61925
    Profile photo of WolfgangWolfgang
    I find it better if the channels are completely muted, when a DCA mute ist activated.
    it is only one asks to the approach
    but if there was a choice, every wishes covered.
    #62216
    Inactive
    ddff
    Haven’t seen that. Standard DCA mute is exactly the same as pulling the DCA fader to off, not turning the channels off.
    However, on the Yamahas, you can choose Post-Only (Default) or Pre & Post (similar to muting the channel)
    [IMG]https://uploads.tapatalk-cdn.com/20170318/824b9d5a12c1010ba1141ac21ac995e3.jpg[/IMG]
    #62219
    Inactive
    I guess Tapatalk image links don’t work…
    #62243
    Profile photo of SteffenRSteffenR
    yamaha… very good example 🙂
    they have consoles build where the chanel mute button does not mute the pre fader auxes
    a nightmare with replugging condenser microphones
    they do sometimes something different
    to mute the channel completly with DCA mute is common sense
    this changes in the last time with modern digital desks
    but on most of them it is switchable
    #62249
    By saying analog I ment all kinds of Soundcraft, Heritage, XL, ATI… Yamaha is well known for messing up things- matrix (mix from mixes) now accepts input as well, mute works in strange way. I heard the X32/M32 also has this DCA behaviour.
    ddff
    #63260
    Profile photo of pete.jpete.j
    +1 – working half of my live analog the other digital – VCA (analog) and DCA (digital) Mute alawys muted the assigned channel (therefore the pre-aux and post-aux). Pulling down VCA is like pulling down fader, pressing mute on VCA is like pressing mute on corresponding channel, and it was one all brands I used (Soundcraft, Crest, Midas, Yamaha, DiGiCo, A&H, Innovation, ….).
    So, it might be a nice feature to have the choice (even useless for me), but it’s more common as it is now in the dLive. If moving DCA fader will alter a pre-fader send, then it’ll be a bug, but I never experienced this so far.
    BUT: As a feature request (and that’s special to digital consoles, but also already implemented in Soundcraft Vi and DigiCo) for doing Monitors I’d love to see the “DCA-to-Mon” feature, so I could f.e. pull down Drums in a InEar mix with the DCA rather than pulling down 8-12 faders.
    Cheers
    #127661
    Profile photo of VP MixesVP Mixes
    I faced the same issue on Avantis yesterday mixing live show and it’s clearly a bug. That moving a DCA fader altered all pre fader sends.
    #127663
    Profile photo of RuneSRuneS
    Most likely the initial post was due to either misunderstandings, or user error. That is not how DCAs work on any AH products.
    Check the pre/post assignment of the affected channels first. Then select the relevant DCA and go to the routing page and check if you accidentally added the Aux to the DCA?
    Does Avantis have MCA options like dLive? If it does, turn it off for all your DCAs.
    It is not a thing (bug) on dLive, iLive, GLD etc., and I feel pretty confident it is not a bug on Avantis either since I haven’t heard a single person complain about it.
    #127711
    Profile photo of ErnestoErnesto
    Are the DCA also acting as MCAs?
